2" coil spacer on 5" lift coils
Those look pretty sweet!! That's just a single arm right, instead of two? I've noticed a couple guys going with singles instead, to me it seems like there would be less binding with just one which is good!
Single radius arm on each side. Lots of guys will chime in and say that the radius arms don't flex as good as the 4 link, but so far I run out of shock before I max out on articulation. I'm running 12" travel shocks.
So far I'm not a huge fan of the DC long arm kit. It articulates well, but aside from hacking into the cab mount to get them on, I hear the tube used in the arms is pretty thin.....
OH!!! I didn't know about that cab mount hacking, that's good to know! I'm not a huge fan of hacking stuff, especially cab mounts!!!
So how do yours mount exactly? And where is a good place to look to buy something like those?
Mine mount to the frame outboard of the trans crossmember with four 1/2" bolts and three 3/8" bolts.
You can find them at dtprofab.com. This is the only pic I can find of the frame bracket before I painted it. They don't come that shiny, I wire wheeled everything and clear coated it. I think they come powder coated now.....
Not sure, I test bedded them for DT, so I got a big break on them. You can call them @ (928) 776-4129.
I might have the new ones back from the powder coater tonight, had 'em bead blasted and clear coated. I'll post pics when I get 'em.
mstep3
44
Jan 18, 2010 09:01 AM
deere nut
Sep 24, 2007 10:40 PM
StealthRam
Jan 6, 2006 02:18 PM
CTD NUT
Dec 15, 2005 11:44 AM
