12valve differences
12valve differences
What, if any, are the differences between the 1st gen 12valves and the 2nd gen 12valves, as in differences between the blocks, cranks, rods, pistons, and heads?
Originally Posted by Fueling around
I know about all of the major differences like injection pump, timing cover, injectors, injector lines. But I was looking specifically for differences in blocks, cranks, and rods. The reason im asking is because im going to be building up an all out P-pump motor and I have an 89 short block that needs to be freshened up and a new set of pistons and im wondering if it would be a good canidate or if I should start with a newer motor?
From: Used to be missoula, montana: Now in Sonoma County California
the cam shaft in the earlier motor has a different profile. dont remember off hand. the pistons work, though the 89 head i think requires something to install 94-98 injectors but i have seen a few people do p pumps on the 89-93s with no problems. just pump, timing cover and injectors. the 89 and a few years in there the head flows a little less than some of the later ones. compression ratio is the same IIRC.
xzlram
Dec 24, 2003 05:21 PM
DC
Dec 5, 2002 09:34 PM
