12v performance
Old Oct 1, 2008 | 09:32 PM
blackdiesel's Avatar
Registered
12v performance
alright, school me. yes, i've nearly worn out the search button but cant find just exaclty what i want. i have a 1992 cummins with a p-pump (industral application) thats rated at 190 hp. what can i do for free to get some smoke and some power out of it? can anybody point me to a good thread that will teach me what i need to know? pictures maybe?
Old Oct 1, 2008 | 09:59 PM
DL1221's Avatar
Search for "fuel plate" in the 12-valve forum. On a p-pump fuel and smoke are controlled by the 1. cam/fuel plate, the profile of plate that you have, and its position in the pump, 2. the AFC housing position, and the 3. the starwheel adjustment.
Try this threat:
https://www.dieseltruckresource.com/...ght=fuel+plate
TST has some good instructions:
http://www.tstproducts.com/installat...tructions.aspx
and this site has some good pics:
http://www.cumminsdatabase.com/read.php?id=58
There is tons of info on this in the 12-valve forum.
Old Oct 1, 2008 | 10:15 PM
DL1221's Avatar
More threads:
Old Oct 1, 2008 | 10:41 PM
Registered
that helps a bunch. i think i've bout got it under control. just wondering which way i screw the star wheel? towards the grill or towards the cab? and the plate goes towards the cab correct? i'll take her out and grind it flat to make a 0 then reinstall it.
what/where is the break off screw..... anything else i need to know? thanks
Old Oct 1, 2008 | 10:52 PM
William12Valve's Avatar
Everything toward the front of the truck/motor. The breakoff screw is on the AFC housing if it is still present on the pump. Hope this helps.
Old Oct 1, 2008 | 10:56 PM
DL1221's Avatar
Moving the plate towards the cab will reduce fuel and smoke, moving the plate forward towards the grill will give more fuel and more smoke. Sliding the AFC housing forwards will give you more pre-boost fuel and more smoke, and moving the AFC housing back towards the firewall will reduce pre-boost fuel. A little goes a long way with with the AFC housing adjustment. TST recommends you keep the new plate in the stock position, slide the AFC housing full forward, and control your smoke with the starweel. Their instructions are the best I've seen, worth reading, see here:
http://www.tstproducts.com/pdffiles/INSRUCT98.pdf
Old Oct 4, 2008 | 10:05 PM
Registered
alright heres what happened. for starters i moved the afc housing all the way forward and the starwheel full forward and got no extra power and no smoke.
So then i pulled the housing off, ground the plate to a 0, slid it all the way forward, reinstalled the housing full forward, and the starwheel still full forward and still got no extra power and no smoke.... What gives?
Old Oct 4, 2008 | 11:26 PM
NMCTD's Avatar
hmmm, kinda sounds like the boost line that runs from the cylinder head to the AFC housing might be disconected or leaking. If this happens the AFC arm won't get out of the way so the governer arm can get into the fueling.
Look at the cylinder head under the intake horn, there should be a small black nylon line that runs from there to the back of the AFC housing. make sure its connected and sealed up good.
let us know what you find
Old Oct 14, 2008 | 07:33 PM
Registered
dosnt seem to have a boost leak in the line.
it has started smoking some now. not sure what changed? hp difference is hard to judge, being as how its in a school bus and has a horrible automatic behind it. however i thought this thing would smoke like my 24v used to with mods? it just smokes a little, but it does feel like it has more power in the upper rpm band.
TxDiesel007
Competition / Pulls / OffRoad
33
Apr 27, 2006 03:54 PM
CruisingRam
Apr 16, 2006 09:14 PM
TxDiesel007
Jun 29, 2005 10:31 AM
Rhino
Mar 19, 2005 07:56 PM
Haney
Nov 19, 2002 03:46 PM
