02 fuel PSI gage hookup
ok, so i am reading all the horror stories and figure my sat. morning job will be installing a fuel PSI gage. one problem, where to hook it? looks like the only way would be to tap the line, or find a fitting that would screw onto the test fitting coming into the injection pump. any slick ways someone has figured out?
Upersleder:
Your '02 (like mine) has a Schrader-style valve at the VP44 inlet. This is a convenient place to tap for pressure readings using a hose like the one offered www.Genosgarage.com
Other options are tapped banjo fittings, or tapped hi-flow adapters, like the Max-flow kit from www.wildcatdiesel.com
PM me if you have any more questions.
justin
justin
Just contact one of the vendors that advertise on our site.
They're the ones that help us keep this site on the WWW and at no cost for the rest of us.
They can give you all the latest and greatest info on what you will need and where to hook up for a particular year vehicle.
Ed
Ed
Here is the best way I have found and solves the ticking gauge problem as well. This was passed on to me by Rod at wildcat.
Get the kit from whomever you wish. It should come with a SS line and fittings. All you need is a tapped banjo bolt for the bottom of the fuel cannister and run your line to the gauge.
38 Cigarette
16
Aug 28, 2015 11:27 PM
schamran
Dec 14, 2009 08:20 PM
nrussell
Jul 23, 2008 08:58 PM
Tommy93w350
Aug 7, 2007 12:15 PM
Dave88LX
15
Sep 4, 2006 09:30 PM
