'02 boost numbers?
Old Nov 9, 2008 | 10:19 PM
jcarrillo's Avatar
'02 boost numbers?
My truck runs about 20 #s of boost all out( foot on the floor and 2500 rpms) and I see alot of people say that the turbo that is on my truck will put out 35#s based on my sig, does this sound right to yall? Its an hy35 by the way.
Old Nov 9, 2008 | 10:40 PM
stevenl's Avatar
i have same exact problem
Old Nov 9, 2008 | 10:54 PM
Flatbed24v's Avatar
get a boost elbow for the waste gate
Old Nov 9, 2008 | 11:10 PM
Tate's Avatar
Numbers sound normal. Wastegate opens around 20, so you will need keep the wastegate from opening. I don't know what your Banks tuner is good for, but you won't be seeing 30 psi with just that.
Old Nov 9, 2008 | 11:19 PM
dodge_24's Avatar
will the boost elbow work on a auto trans how and where does it go would like more boost and no codes i tried the edge comp on ez mode and same boost ive heard the edge ez does boost fooling and got the same boost
the banks tuner works alot better then the ez
Old Nov 9, 2008 | 11:23 PM
jcarrillo's Avatar
What do you mean boost elbow for the wastegate?
Old Nov 9, 2008 | 11:35 PM
Flatbed24v's Avatar
I don't know about auto's cause I have only had sticks but mine hooks into to hose coming off of the waste gate going back into the exhaust. My elbow is not the adjustable kind, it has a very small pin hole in it to allow minimal amount of air to pass
Old Nov 9, 2008 | 11:47 PM
dist5mxer's Avatar
my 2000 auto runs 28-29 psi all out..
Old Nov 10, 2008 | 01:10 AM
Dinner's Avatar
These fellas are talking about a "boost elbow" that replaces the stock fixed brass fitting on the front of the compressor housing (if it is a HX35). There is a rubber hose coming from it that runs back around to part of the wastegate actuator. Even with some sort of programmer that has boost fooling, unless you install a boost elbow (or J hook depending on turbo) then you will always see max 20 Psi give or take.
You can see the boost elbow on my stock turbo, has the little black allen key screw so you can adjust max Psi levels. On a stock HX35, you don't really want to get above 34 Psi. Anymore than that and you are running out of the turbo's efficiency range and will be creating more heat than good.
Old Nov 10, 2008 | 01:33 AM
Flatbed24v's Avatar
ya that's what it looks like, nice pic and thanks for clearing up the muddy water I made I wasn't sure of where it ran and was being to lazy to walk out side and look LOL
Old Nov 10, 2008 | 08:37 AM
JIT's Avatar
JIT
Your HY turbo has a hard line where the boost elbow would normally go so you'll have to use a j-hook to keep the wastegate shut longer. Thats the only way you are going to build more boost without changing your turbo.
The HY is capable of 35lbs but its not very efficiant past that! If I were you I would sell the HY and put an HX35 on it with an adjustable boost elow like shown above. They are a cheap direct bolt in upgrade for the Auto's!
Old Nov 10, 2008 | 08:48 AM
jcarrillo's Avatar
Does the adjustable boost elbow come on the HX35 or do you have to buy it aftermarket and put it on. And, if so where do you get them?
Old Nov 10, 2008 | 09:50 AM
can17's Avatar
The adjustable elbow is an aftermarket add-on. You can get them from several diesel performance companies, TST Products, for example.
Old Nov 10, 2008 | 10:03 AM
jcarrillo's Avatar
Thanks, yall have been alot of help. I will try that. I think I have a donor Hx35 coming in pretty soon. I'll post my findings after all is said and done.
Old Nov 10, 2008 | 12:18 PM
REDNECK-WELDING's Avatar
what does this J hook look like?
