01.5 24V NV5600 Clutch
Good mornin! I reciently replaced the clutch in a friends truck with South Bend 1947 CON OFE. There is around 3500 miles on it now and its already slipping. When the engine is pulling between 1200-1900 RPMS there is a shutter, and a vibration that comes from the clutch. Plus when you stop and get out of the truck you can smell something burning (clutch) coming from under the truck...
I KNOW I installed the clutch correctly, I used to replace them all day long on 10, 13, 15, 18 speed Eaton's. I was told that once the clutch plate itself loosens up the problems will go away. I would think this clutch is fully broken in by now!?
Any ideas??
Any ideas??
I have the same clutch and have had no issues with it now with 35k miles on it .I tow real heavy loads 38k gcvwr and run a smarty and mach1.6 its holding 335hp/800tq. so with that said somethings up...Did not break in the clutch right,BAD clutch,bad install,oil on clutch,bad pressure plat,to much power?bad driver .
not pointing fingers just possabilities . Give peter a call at SBC he can give you more ideas
Robert
Robert
I called South Bend, they said to give it time and break it in somemore. I dunno. Both him and I have drove it, it did the same for both of us, but only when towing.
The install when CLEAN and flawless. The truck only has Bosch 300/275's. Stock turbo and no "chip" at this time.... Should be able to hold that power without a problem..
Mine has been great and never slipped. I installed a new flywheel with the heavy duty bearing and the upgraded master/slave cylinder combo. On a regular basis I tow 16,000lbs. If it were my truck I would be tearing into it to see what was up, you have far exceeded the break in period.
king5335
26
Jan 17, 2010 07:57 PM
buddy26
16
Jan 14, 2009 07:29 PM
bhuffstutter
0
Oct 17, 2005 09:41 PM
fishin fever
Nov 29, 2003 11:29 AM
