View Poll Results: what do you think?
Hoss is da man, no
25
33.78%
Geico's question. He knows, yes
42
56.76%
your both wrong its a vto
9.46%
Voters: 74. You may not vote on this poll
will the plane fly?
Old Nov 30, 2005 | 02:53 PM
  #196
rammtuff's Avatar
Taking off requires a upward net force. This is caused by LIFT. So, with Newton helping us out a bit here, we will prove that the plane cannot take off:
Starting out, at v=0, the plane is not moving through the air, hence the total net force is still a vector pointing DOWNWARD (this is the airplane's weight). When the airplane starts moving (by providing forward thrust) the conveyor belt reacts and does not let the plane roll forward RELATIVE TO THE AIR. Velocity relative to air is STILL zero.
Key point here: if the airplane does not move THROUGH THE AIR, the lifting force is NOT generated.
And thus the airplane does not take off.
Old Nov 30, 2005 | 03:10 PM
  #197
FD5's Avatar
FD5
Originally Posted by Hoss
Air speed and ground speed are equal. 1 mph is 1 mph whether it's in the air, on the ground, or on the water.
Let's take your sea plane analogy and try to take off in a raging river. Say the river ALWAYS matches the speed of the plane, but in the opposite direction. Just like with the conveyor, that plane will never get up. Same with a ski plane if you put it on snow that is always moving at the same speed as the plane but in the opposite direction.
Your analogy of the sea plane is correct in that there is friction (water again a fixed object, the planes belly), however the plane we are talking about has wheels that turn (unless they forgot to release the brake). Lets reverse our action, lets say the plane is going to land on this moving conveyor belt, your saying it can't, I'm saying you won't hear the "errk" of the tires because the conveyor belt will be traveling the same speed. When the brakes are applied and the wing flaps down the plane will slow as will the conveyor.
My .02 cents worth, we are still at the lounge.
Old Nov 30, 2005 | 03:24 PM
  #198
Geico266's Avatar
Originally Posted by FD5
While everyone was trying to figure this out, the plane has already taken off, flown around and landed, the pilots are at the bar in the lounge with me.
Can I join you guys? I'm buyin! lol
Old Nov 30, 2005 | 03:28 PM
  #199
fozzy777's Avatar
OK I lied this is my last post.
Hoss you might want to check this out. http://www.avweb.com/news/columns/191034-1.html
I hope the link works.
I'am not even gonna say if it will fly or not. My head hurts.
Old Nov 30, 2005 | 03:29 PM
  #200
Hoss's Avatar
Thats MR Hoss to you buddy!
Okay...I've got a Triple 7 pilot that says the plane won't move. That means I win.
Old Nov 30, 2005 | 03:30 PM
  #201
Timmay2's Avatar
Yes... 10 mph.. my understanding is this is a typical bulldozer:
the track on top is the same as the track on bottom.
Old Nov 30, 2005 | 03:32 PM
  #202
rammtuff's Avatar
OR:
The plane can take off only under these circumstances.
If the engines were routed directly infront of the leading edge of the wing thereby creating pressure difference between the top and bottom (lift) of the wing effectively making it a vertical takeoff machine
Old Nov 30, 2005 | 03:41 PM
  #203
Hoss's Avatar
The problem with their experiment is that it did not meet the conditions set forth in the scenario. They DID have a conveyor runway, but it did not exactly match the speed of the wheels (otherwise the plane would have never moved).
Old Nov 30, 2005 | 03:44 PM
  #204
fozzy777's Avatar
I think that's the rub. The conveyor matches the speed off the wheels not the plane.
Old Nov 30, 2005 | 04:00 PM
  #205
Geico266's Avatar
"Once you have flown, you will walk the earth with your eyes turned skyward, for there you have been, and there you long to return. "
Author is stuck on a very large tredmill somewhere in South America.
Old Nov 30, 2005 | 04:02 PM
  #206
Geico266's Avatar
YES, YES, YES! You got it! That's what I've been trying to say! Now if I can just get Hoss & derk to think past earthly bonds.
  #207
Hoss's Avatar
The speed of the plane is 0 mph.
Old Nov 30, 2005 | 04:04 PM
  #208
Geico266's Avatar
Hoss, You are a very intelligent man (should have gone to Baylor, buts that's another story ) think this through before you type another post.
To your theory, you are correct if the wheels are driving the plane. BUT the wheels are not driving the plane. The engine is pushing on the atmosphere independant of the conveyor. The only way to cancel out the forward motion of the thrust of the plane is to tie it down or create a headwind to match the thrust, but even in the latter senerio the plane would lift off at rotation (lift off) speed and fly. (ground speed 0)
Old Nov 30, 2005 | 04:05 PM
  #209
iker42's Avatar
Geico266,
Look what you started....WE WANT ANOTHER BIG BRAIN TEASER!!!!
Old Nov 30, 2005 | 04:09 PM
  #210
Geico266's Avatar
Originally Posted by iker42
Geico266,
I just a bill in the mail for wasted bandwidth from Jack & TOP.
We could have built the conveyor!
