Welder suggestions please
Penetration is controled by amperage and flow is through voltage. Flux core is basically stick welding as there is no need for gas, the flux is the shield against O2 contaminating the metal in the moltant state.
Thanks for the info, Im not much of any expert on welding. Ill try that the next time Ive got something to do. I dont hardly ever weld much so I dont get to mess with changingsetting that often. I just dial close enough to do what I need to do. Ive just been told by a few people from time to time it was probably the flux core stuff, granted Im not sure if they really knew either. Thanks for the advice though. Usually I get a pretty clean bead with hardly any splater, and usually its more me and not the welder!!
Thanks again.
Thanks again.
Lincoln, Hobart, and Miller are good welders. By the way, to find how thick a welder can weld in a single pass, divide the metal thickness level to determine how many amps will be required. I.E. 1/4 metal requires 250 amps, 1/2 metal requires 500 amps for a Single pass.
Bottom line, with proper technique and setup, the 175/180 class MIG's can weld 1/4 adequately for most applications.
Stock03,
I just re-re-re-did my exhaust again, and rented a wire-feed welder from the local Home Depot. Portable and ran on 120V. They also sell that same unit for between $250 - $350. That was a very nice welder. Maybe you should rent one to test it out. Just a suggestion.
Of course I need to buy the safety gear as well.
The Home Depot rental was something like $33 (4 hours) or $44/day. It came with gloves and mask. I had to buy a spool of wire. I think that was $9.
Some guy came in right behind me to rent the welder. Home Depot only had the one. I got his name/number and when I was done, I went and did his job. He gave me $30 cash.
Bacon sizzling, yep, that's what I was gonna say. You know how they taught us how to weld at the welding school I went to. Well, at least with the teacher I had for over a year and a half. He had been welding for 25 or 30 years and knew his stuff.....anyhow, I read the book, for Mig, then answered the questions at the end. He then stuck me in a booth, said, "Go dig around outside and find some scrap metal and play with it for awhile". So I did that for the rest of the night. Next day he said, "Go get some scrap from outside, bevel the edge at a 45 degree angle, don't make it to thin, butt the two pieces together and make your first pass, then a cover pass". He told me you wanted a thin line on the other side, showing that it penetrated. After many days of doing this flat I got confident. So I cut my plate into 3, two inch wide sections and he put them into the press to stress test them. They all cracked, some in the center, some at the edges. Back to the drawing board. I'd say I worked on that for about 5 weeks, night school, three times a week for about 4 hours a night until I finally got enough practice to run a solid bead, a cover pass that would hold up under the test.
That was just the beginning. Next was welding horizontal, vertical up and then vertical down and lastly, overhead. Each time I started a new position I thought, no problem, I just did the flat and passed, or I did the horizontal and passsed. It was not that easy, seemed like there was just a little bit of a difference in the technique to get a good strong weld. Maybe that's just me, but by the time I was done with the overhead welding part and saw my pieces get bent all out of shape and no cracks.....I was darn proud of what I did.
Basically, long story........long, practice, practice......and more practice. Stop by your local welding shop and ask if you could pick through there scrap metal bin.....tell them your going through welding school and the program is under funded and you need some scrap to practice on. I was actually in school, but it worked out great. I got a bunch of steel from several places and they were all willing to let me dig around there metal bin. It helped out for the other people at school the night I came in with a truck load of practice metal!!!
