Are There Any Forklift Specialists Here?
Old May 17, 2013 | 10:55 AM
irocpractice's Avatar
I need info on a very very old Clark forklift.We think the model is an AU 248,at least from the numbers we can find.All I want to do is change the engine oil and check the hydraulic reservoir level.I can say it is a 4cly gas unit with a 3 stage mast and appears to be around 4000lbs capacity.Oh,and it's free .
Old May 17, 2013 | 04:22 PM
j_martin's Avatar
It's old iron. Put motor oil in the motor, and hydraulic oil in the hydraulics. I'd use 10W30 oil, and 20 W hydraulic oil, (ISO 46 I think)
Any modern fluid is worlds above anything that was available when the machine was made, and the machine itself is just basic engine - worker stuff. No rocket science there.
If you want to read----
http://www.clarkmhc.com/company/faq.asp#manuals2
Old May 17, 2013 | 05:41 PM
Thank you veddy veddy much,now to find the hydraulic reservoir.
Old May 17, 2013 | 07:15 PM
Tallguy67's Avatar
Is there any chance the reservoir is under the seat? That is where I found it on my IH350 Utility tractor.
Old May 17, 2013 | 09:47 PM
j_martin's Avatar
Look at the main cylinder. If the shaft is considerably smaller than the shell, the hydraulic oil tank is likely pretty small. There's no need for pressure on the top of the cylinder, but it can be used to store oil.
Mcmopar
Feb 15, 2010 02:21 PM
wannadiesel
Jan 22, 2009 05:16 PM
AlpineRAM
Jun 25, 2008 08:00 AM
iker42
Nov 2, 2006 09:23 PM
Ripper406
Sep 11, 2005 07:59 PM
