stuck motor?
Old Jun 3, 2006 | 07:12 PM
mainer's Avatar
I'll have to suck the mystry oil out and pour some coke down there.
It is hard to let it sit there...I just wanna get it going.
Coop
Old Jun 4, 2006 | 05:46 PM
mainer's Avatar
Off with its head
Towed it down the road in first gear and it just slipped the clutch. It was smoking out of the timing hole in top of the trany .
So out comes this motor......In goes the 134hp 16valve . I've started to pull the head, It'll come out in pices much easier.
It should be a fun little car when it is done.
Coop
Old Jun 4, 2006 | 06:18 PM
G1625S's Avatar
PB blaster. My buddy has a 41 ****** that sat for some 13 years. Stuck. Sat for days with wd-40, bar on the crank etc ect. I told him to give the PB a try---he poured about 2 cups down each hole and the engine spun over within hours! I swear by the stuff, but that even impressed me. Give it a shot.
Old Jun 4, 2006 | 07:03 PM
mainer's Avatar
PB sat in it for about 6 hours today. It did nothing. I think something is bent, that thing is suck somthing tight. I'm starting to think that it would be better to rebiuld the current motor. It'll be an antique in a few years and it will be worth more with the orginal motor. We'll see whats worng with it when I get the head off and the motor out. All I have to do is pull the down pipe and lift the head off.
Coop
Old Jun 4, 2006 | 07:12 PM
robert chilton's Avatar
If you think PB Blaster is good look for some stuff called Free All. When I find it it I buy it by the case!!
Old Jun 5, 2006 | 01:57 AM
AlpineRAM's Avatar
Originally Posted by mainer
Off with its head
Coop
To unstick an engine you will want the highest torque from the tranny to the engine, therefore you will want to use the highest gear and you will want to start to drag with the clutch released instead of pushed....
I second you on the antique with original engine thought...
AlpineRAM
Old Jun 5, 2006 | 07:10 PM
Journier's Avatar
WELL , hmmm, this post got me motivated to get my 150 CFM Ingersoll Rand Compressor unstuck!
**** things muffler rusted through about 4 years ago, and before i noticed the problem, rain water poured into the cylinders
its a Ingersol Rand Gas engine, and the thing seems pretty built, heavy duty ?
its a 4 cylinder inline engine, Gas fuel :/
anyways today i ripped the head off, and sucked anything out of it.
i have coca cola sitting in the cylinders right now, if that doesnt work, ill try pb blaster for a day.
If that doesnt work im pouring muratic acid in it for 10 minutes and see if that will break the rings from the cylinder walls
hmm any other suggestions?
i have probably put over 800 ft/lb's of torque down on the front pulley
trying to spin the thing, she's sealed good, cant believe its sealed up so strongly.
Old Jun 5, 2006 | 08:11 PM
mainer's Avatar
I pulled the head cut a 2x4 to fit in the cylinder. I beat the crap out of that 2x4 till it broke loose. Than I cranked it over a few times with a socket on the crank pully. The inside of the cylinder is covered in rust.
I've got one more bolt, which I just stripped, on the trans axle than the motor is out. I'm not sure yet what I'm going to do for a motor, but I figured that if I had the head off it was just a little more to pull the motor. So if I decide to reuse the old motor I'll be able to rebiuld it.
Coop
Old Jun 5, 2006 | 09:15 PM
Journier's Avatar
i was tapping the pistons with 2x4 + Sledge hammer
but im sorta scared about breaking a piston into pieces so i was just giving steady little whacks but nothing freed up any :/
birdboy
Dec 12, 2018 09:02 PM
birdboy
Apr 21, 2012 09:44 PM
Baja
Jan 29, 2008 08:17 PM
coupdetat
Feb 17, 2007 12:52 AM
04ctd
Sep 14, 2004 04:43 PM
