SMOKE ??
Old Sep 2, 2003 | 11:05 PM
dieselcrazy's Avatar
SMOKE ??
I was always told that diesels that are pouring out the black smoke are just wasting alot of unburnt fuel. any truth to this ?? whats the theory on .. to smoke or not to smoke??? later guys, scott
Old Sep 3, 2003 | 07:56 AM
Hoss's Avatar
Thats MR Hoss to you buddy!
Re:SMOKE ??
True. BLACK smoke = unburnt fuel. So...while smoke may look cool....it means your engine isn't burning fuel efficiently...which means you're not making the power that you could be.
Old Sep 3, 2003 | 04:26 PM
Re:SMOKE ??
Smoke means you need more boost. Get more boost, smoke gone. Need more fuel. Too much smoke, need more boost. Repeat until you run out of money.
Old Sep 3, 2003 | 04:34 PM
Captain's Avatar
Re:SMOKE ??
Can you help it when it puts out smoke because your around 1100 rpm and rising but not at the point to build boost yet?
Old Sep 3, 2003 | 06:31 PM
BigBlue's Avatar
Re:SMOKE ??
You could back off the fueling down low to help with that (I don't know how you UNDERvalved people do that ). On a PROPERLYvalved engine , you'd adjust the low boost fueling levels on your box (if you have one) down. Stock, diesel's don't smoke much, if at all.
Old Sep 3, 2003 | 07:51 PM
Re:SMOKE ??
wannadiesel
arent you the fella i talked to about doing a kdp ?? im in lancaster.
Old Sep 3, 2003 | 09:03 PM
Captain's Avatar
Re:SMOKE ??
Why would I want to power down my truck ;D
And you PA people should really join my chapter. Thats what the cool kids would do
Anywho....
Old Sep 4, 2003 | 05:14 AM
AlpineRAM's Avatar
Re:SMOKE ??
[quote author=Captain link=board=10;threadid=19153;start=0#msg180175 date=1062624890]
[/quote]
You can try to adjust the AFC a little lower. The AFC starwheel is under a plug to open with an 8mm allen on the back of the pump. Rotating the top of the starwheel towards the engine gives more fuel under low boost, away from the engine less fuel under low boost. Reducing fuel under low boost will increase turbo lag a bit- if you have too much fuel at low boost you will douse the fire in the cylinder and therefore lose pwer too. I'd go and try to adjust some clicks away from the engine and go for a test ride. If you make a note of the clicks you have doen you can go back to the former setting. (This is the free lunch)
If you want to do it properly you can either go for a smaller exhaust housing to increase spoolup, but you'll lose top end flow and may run into EGT troubles. Or really properly you can do twins, 4K GSK, AFC mod, valet switch, injectors, O-ringed head etc ;D
HTH
AlpineRAM
Old Sep 4, 2003 | 07:31 PM
Re:SMOKE ??
hey cap im still waiting on info buddy
Old Sep 4, 2003 | 07:33 PM
Re:SMOKE ??
alpineram ... valet switch ??
Old Sep 5, 2003 | 12:11 AM
AlpineRAM's Avatar
Re:SMOKE ??
[quote author=dieselcrazy link=board=10;threadid=19153;start=0#msg180714 date=1062721983]
[/quote]
Thingy to make your AFC work or not (for turning day into night behind you), actually I don't know the vendor.
Sorry
AlpineRAM
Old Sep 5, 2003 | 07:09 PM
Re:SMOKE ??
oh thats ok just wondered what it is
bensdad_canada
May 9, 2005 10:56 PM
dhe9
Nov 14, 2003 07:31 AM
PK
Oct 19, 2003 10:28 AM
jbs007
Jul 8, 2003 01:29 AM
97CTD
Mar 17, 2003 08:14 PM
