Small Block Chevy Question...
Hey guys,
I was wondering if anyone can tell me what I can do to make my small block chevy start faster.... She is very cold blooded, but takes a while to get fired up... What can I do??? Thanks...
Originally Posted by ChevellePull
Hey guys,
Edwin
there's just a little variety out there.
Edwin
Edwin
but, if you mean its not turning over fast enough, battery or alternator. if it takes too long to get running, fuel, either too much or too little, or weak spark. which could also be battery/alternator
MSD ignition module can do wonders for it. Also go through your carb to clean and adjust per specs. [especially the choke adjustment]. If it's an older engine then a basic tuneup is needed to get everything in balance. There's no shortcut to point by point test procedures to troubleshoot actual problems. That is it's pretty hard to fix a problem when you don't know what it is.
JimmieD
JimmieD
JimmieD
JimmieD
Plugs, wires, cap and rotor, and fuel filter come to mind, unless it is a fully electronic ignition. If it is a TBI they can be a little slow to start, if it is a carb then you may have more work to do. I had a 95 Chevy 350 and with fresh plugs, wires, cap, rotor, and fuel filter, it fired right up. That's about all I got!
good luck
good luck
Originally Posted by derek840378
mine too. 318 w/ 2 bbl Holley 2280/6280
Made things like a 283, 302, 305, 327(both SJ and LJ). Ooopps, forgot about the oddballs. 307, 305, and others I wish too forget. Something like a 265?
Dang, I now I am going through withdrawles(sp). Wish I would have never gotten rid of my '66 Nova.
you forgot the best of them all.. the 350.. and of course the 400 that likes to over heat with those ingenius steam ports..
Then to make the 350 better a 400 crank in a 350 Had this one running for 150K when I sold it... Lots of torque and dependable.
Hard starting can be a caused by a lot of different reasons.......is it acting like it's not getting fuel to the carb or what's it doing?
