Skunks .... Ughhhh
Skunks .... Ughhhh
ok, so whats the trick to getting rid of a local skunk or 2 without getting sprayed ? and im not sure a weapon is an option as i have to be careful of the neighbors houses. i was thinking a can of tuna and some rat poison but im worried about neighborhood pets getting into it. any tips/advice ?? thanks guys
moth ***** might work lot's of moth ***** or cbs in a .22 smaller than a .22 shorts sounds like a cap gun , but will get the job done, the live trap sounds good , but if you don't have one already their kind of pricey
A skunk will only spray if startled or approached head on.
They are easy to catch, without getting sprayed, if you will come at them sideways and avoid direct eye contact.
They will not spray in the dark, either; so, a blanket quickly dropped over them is a good means of capture.
Then, you can re-locate them to a more suitable area.
They will spray if shot or trapped.
The horse trough full of water is for the "more suitable area"
I've caught them in a live trap in the barn. Set the trap on an old sheet of tin. I used dry cat food. Drop a piece of carpet over the trap after he's in there. I jabbed a hay hook in the metal and just drug it outside and let him loose, then used my Ruger 22 to direct his path!
You're wasting good tomato juice if you use in on your pup after a skunk sprayed him. Do a search for skunk spray. It's a tad of dawn dishwashing soap, baking soda, and hydrogen peroxide. You put that on the dog, leave it about 5 minutes, rinse it off and the smell is gone. You can use the same formula to get cat/dog pee out of carpet to.
They are easy to catch, without getting sprayed, if you will come at them sideways and avoid direct eye contact....
He was pukin' Wrong on ALL counts!!!!
It sure was difficult to drive that car...
I thought the A/C would help, but the outside air intake was behind the hood RIGHT BEHIND Mr Stinky...
K.
K.
K.
Originally Posted by Begle1
So, um, he couldn't ride on the truck?
I had a ratty '65 VW back then and he wasn't going to even get close to my ride!...
K.
