residential use tractors
Old Sep 23, 2005 | 05:58 PM
jj3500's Avatar
Smile residential use tractors
hey all
been shopping for a small tractor ~ 30 HP. new purchase. narrowed it down to kubota B3030 or new holland TC33. they are close in power and capabilities.
anyone have these units or similar? pros and cons?
looking to purchase soon.
THANKS
Old Sep 23, 2005 | 06:22 PM
G1625S's Avatar
I've heard the Kubota has weak hydraulics, but no personal experience. My cousin has a 28-ish hp New Holland and he loves it. I putted around in it for a while and it seemed pretty stout. Two class A machines--can't really go wrong.
greg
Old Sep 23, 2005 | 06:39 PM
rammtuff's Avatar
John Deere.
Old Sep 23, 2005 | 08:25 PM
JPDiesel's Avatar
Mo
Buddy has the Kabota, seals blew out <2 yrs old. Had to have service tech come fix it. Would not move, stuck in field. Just my .02. Good luck with your choice.
Old Sep 23, 2005 | 08:36 PM
Marine's Avatar
Veteran: Marine Corp
My Uncle has a Kubota, and it has worked very well. In fact, I dug about 50 post holes at my house with it. (Don't tell him)
...just kidding.
Old Sep 23, 2005 | 08:43 PM
MedicShawn's Avatar
You might try http://www.tractorbynet.com/ for LOTS more info and opinions.
Old Sep 23, 2005 | 09:11 PM
TreeFarm's Avatar
Take a look at http://tractorbynet.com. You will find more information and help than you ever thought possible regarding compact utility tractors.
Old Sep 23, 2005 | 09:33 PM
NHDiesel's Avatar
Well my buddy's kubota that he purchased new around a month ago is giving him headaches. First it had weak hydraulics. The dealer said they are fine. Then it broke a shaft for the rear PTO that runs the hyd. for the hoe. Not while digging...just when he was showing a friend, and moving it around. The dealer fixed it, which required a fair amount of disassembly. He got it back and it wouldn't move. They had the throttle cable unhooked still!!! He fixed that, went to move it, and the hoe almost fell off. They didn't have it attached properly! He found several more problems with their repair. Now, a couple weeks later, it broke the same shaft again!!!
Jim
Old Sep 23, 2005 | 09:42 PM
JKM's Avatar
JKM
I am a tech for kubota, and i wouldn't actually reccomend anything else.
I am not a fan of the glideshift transmissions , i like the hydro much better.
As for the last post , that is bad mechanics , not a bad machine, they obviously didn't look for what caused the shaft to break. it's not the machines fault. I would suggest finding someone a tad more knowledgeable. And yes it would be a huge job to replace that shaft.
Old Sep 24, 2005 | 05:37 PM
wana12v's Avatar
On our farm we have used kabota's since i was a little kid 34 horse and 48 horse and they have allways been great tractors, of course so has the old 2020 john deere.
Old Sep 25, 2005 | 05:06 PM
cumminsdriver635's Avatar
Im a john deere fan myself, but of the choices i would probably take the kubota. Massey Ferguson also has a decent looking utility for probably cheaper than either of the ones you mentioned.
Eric
Old Sep 25, 2005 | 07:20 PM
TreeFarm's Avatar
Eric
Other lower cost but well built, reliable brands are Kioti, Branson, Century, and the Korean made Mahindras. There are other brands, but I know these are good makes.
The dealer can make or break any brand, so it pays to check him (or her) out carefully.
Old Sep 25, 2005 | 09:18 PM
NHDiesel's Avatar
My brother in law has an early Kioti. I laughed when I first heard about them, but that machine is much smaller than my father's kubota, but will do twice the work. My father's Kubota can't pick the bed off a Toyota pickup...that Kioti can pick the entire back of my CTD off the ground without a problem!!! Don't tell me Kubota's problems are with mechanics...2 Kubota owners I know have been to a total of 4 different dealers trying to get the hydraulics to work decently, with no luck. They get told repeatedly that the hydraulics are fine.
Jim
Old Sep 26, 2005 | 03:03 AM
Barry St John's Avatar
I've got a small 20hp Kioti and for the price you can't beat it. No problems yet with 60 hrs digging in mixed rock soil.
Old Sep 26, 2005 | 03:21 AM
deere nut's Avatar
I have an 2003 Case DX29 4wd, hydro and front end loader. I havent had any problems with it and it is a good tractor. I was looking at JD 990 (used), Kubota L2800 (new) and the Case (used with 500 hrs). It came down to money and the best/nearest dealer. I have owned many John Deere tractors (and other brands) and JD is my favorite but that doesnt mean I will pass up a good deal when i see one.
