Remote Start Help (non dodge)
Old Dec 22, 2003 | 05:52 PM
I PASS GAS's Avatar
A while back I was asking questions about getting my girlfriend remote start for her car (2000 Mercury Cougar). Well someone suggested the AviStart 4400 (Made by DEI). I read up on it and it looked like a good unit so I ordered it and I have begun to put it in. I got some schematics off of the internet and they are good for the most part, but it is missing two wires that I need. One is the Park/Neutral switch on the gear selector, and the other is the dome light wire.
Does anyone know where I can get schematics online for cheap/free? I already looked on the12volt.com and they do not have schematics for this car.
Any help will be appreciated. I'm trying to get this done by Christmas morning so I can have her open up the remotes out on the deck and have her push the button.
Thanks!
Josh
Old Dec 22, 2003 | 06:32 PM
kandgo's Avatar
Re:Remote Start Help (non dodge)
I wonder if the local dealer would help you,I would go straight to the parts and ask,if they are good guys they should help you out with what you are looking for, Goodluck Rick
Old Dec 22, 2003 | 07:54 PM
lil red cummins's Avatar
have you checked your local library. some have really good technical manual sections. again, not all, but some. around here there is only one library in the whole county that has the good stuff.
jim
Old Dec 23, 2003 | 07:51 AM
hellotbone's Avatar
Constant 12V+ Red Ignition Switch Harness
Starter Gray /White Ignition Switch Harness
Ignition Green Ignition Switch Harness
Accessory Yellow or Yellow/Green Ignition Switch Harness
Tach Brown/Blue Or Brown/Green Engine Coil Pack 2 Cylinder Setting
Neutral Safety Wire Black/Yellow (-) Switch
Brake Switch Orange/Yellow ( +) Brake Switch
Trunk Pin Black/Orange (-) Passenger's Kick or Light in Trunk
Parking Lights Red/Blue (+) And Red/Yellow Isolate Switch or Harness
Hood Pin Black/Yellow (-) Theft Module behind Glove Compartment
Factory Disarm Black/White Driver's Kick Panel or Theft Module
Door Trigger Black/Red (-) And Black/Green Theft Module
Door Lock Yellow/Green (-) Driver's Kick or Theft Module behind Glove
Door Unlock White/Green (-)
Driver's Lock Yellow/Black Right Kick Panel
Driver's Unlock White/Black Right Kick Panel
Passenger Unlock White/Black Right Kick Panel
Windows Up LF=White, RF=Yellow/Green
Windows Down LF=White/Purple, RF=Yellow/Purple
Old Dec 23, 2003 | 01:20 PM
I PASS GAS's Avatar
Jamie:
You are the MAN!!! You have no idea how long I tried tracking down that door trigger wire for the passenger side!
Your information still does not list the dome light wire, is there a reason for that?
Thanks again man!
Josh
Old Dec 23, 2003 | 01:22 PM
hellotbone's Avatar
that's all i got
AndyZ
32
Dec 6, 2009 11:46 AM
Undertaker
Oct 26, 2009 03:02 PM
Megaramasaur
Jan 27, 2007 10:07 PM
FirstDodge
19
Oct 19, 2006 05:26 PM
I PASS GAS
Nov 6, 2003 10:25 AM
