question about using relays
If i were going to install relays, much like the headlight relay diagrams that are on the site, where does the fuse go?
According the diagrams drawn out and posted on the site, the fuse is between the headlight switch and the relay, not the battery and the headlight.
If i were going to put my headache racks lights on relays, can i have the fuse in between the switch and the relay, or does it need to be in between the relay and the battery? The setup that i want to do is as follows:
battery--fuse--switch--relay--lights. Does this work, and is the system protected?
It depends on which part of the circuit you wish to protect.
fuse between the switch and relay, will protect the smaller wires from overload if the relay goes bad.
fuse between the battery and relay will protect the battery and heavier wires if the lights get shorted.
My advise. protect both.
so in theory, i could use use a smaller amp fuse inbetween the switch and relay, since there is less amperage in there, and larger fuse between the relay and lights, since there is more of a load there, right?
Thats kinda what i was thinking. I'm building a new switch/control panel for all my electrical stuff, and i'm doing as much wiring as i can inside, since its snowing out and i have a broken leg.
If the individual switches are non-critical, you could fuse your panel instead of individual switches. HOWEVER, if a switch or relay go bad, you will loose power to everything in the panel.
chuxtruk
Apr 8, 2006 10:41 AM
