paint question for the house
Im having a paint issue in my house.
the water based latex house paint on the market today doesn't stick to the trim in my house. by doesn't stick, I mean painters tape will peel it off in large chunks. the only way paint will stick is to sand off the old paint.
my question is, what is the old paint? Ive lived here about 10 years, the house wasn't that dated and other than a couple spots I covered with pictures, the walls didn't "need" paint, but we are starting to make the rest of the house a bit more us.
non permeable gloves
That means rubber or latex for you folks from Oklahoma
No, no you don’t have to thank me its all just part of the service.
It could be that there is some oxidation of the old paint. Is this occurring only on the outside?
oil or enamel john, as above.. it isn't sticking due to the smooth surface below....
A. chemical coat/strip as above (lots of work navy man)
a simple wipe down with muriatic acid may get the gloss off but careful about the eys, nose with that stuff.
B. 220 grit sandpaper on the palm sander prior to any paint.
C. self etching enamel paint- very expensive but it is the coating used to cover seal damaged areas in government buildings...do dit dooo
paint it Navy grey with left over WW11 paint....
hard to find any paints now with toulene (think acid etching) but reading ingredients may be neccesary.....
where are your son-in laws???!!! heheheh
you want maby I should say "DUuuuuuude"?
It’s just that I felt our friends to the north could use some assistance with the big words.
Back on subject the others most likely have got it right the surface is to smooth or as I mentioned before oxidized that you will need to ruff it up a little.
I was doing the exact thing a few months ago. The trim was painted (by me) with a water based gloss paint. I had to sand it with a 220 grit sand paper IIRC to get the new paint to stick and not peel up with the blue painters tape. A lot of extra work but the finish is perfect this way.
The wife gripes enough about the sanding dust, I wouldn't even wanna fire off a sand blaster in the house.
Have you priced trim? Im cheaper than that....
