old dumper w/ plow cummins conversion??
Old Apr 21, 2004 | 05:11 PM
jaconst's Avatar
Question old dumper w/ plow cummins conversion??
I seen a old 1-2 ton truck with plow maybe international or frieghtliener? I will try and get some pics. think I could get a cummins and drive lines to work together?
Old Apr 21, 2004 | 09:39 PM
Haulin_in_Dixie's Avatar
Re: old dumper w/ plow cummins conversion??
Sure, if the truck has an SAE bell housing you can even bolt one to the transmission, any junk yard can supply the SAE adaptor for the Cummins.
Old Apr 22, 2004 | 12:39 PM
Redleg's Avatar
Good chance. I know the 727 IH used is a different bolt pattern on the B.H. than stock Dodge, but so is the Cummins. They may both use the Industrial bolt pattern. I think the hard part would be fitting an inner-cooler, but you don't necessarily need one. They did have inline sixes, as well as v-8's. Should be Dana 44 axles, Ford/jeep bolt pattern, Dodge matched too didn't it?
Old Apr 22, 2004 | 01:18 PM
Oh we are talking 1/2 ton, I thought bigger. The International (not scout) used a v8 of 304 or 345 cubes. The engine was a takeoff of an Olds block and if I am not mistaken the bell is the same bolt pattern. While the Scout may have had Dana 44 the full sized pickups and surburban types were quite heave of a build. As was said, there was also an older straight six. These v8 trucks were hefty vehicles and would easily get 250 to 300k miles on them before rebuild. Thinking about it there was also a 200 something v8 on the same block.
Old Apr 22, 2004 | 11:58 PM
jaconst's Avatar
i'll try to post the pics I took of the truck I have no idea what it is the owner was not around when I looked at it.
Old Apr 23, 2004 | 12:10 AM
jaconst's Avatar
look in my member photos I have 3 pics of the truck I have no idea what it is? what do you think??
Old Apr 23, 2004 | 12:27 AM
Can't find them, where are they?
Old Apr 23, 2004 | 12:44 AM
jaconst's Avatar
I guess they have to be approved first
I could email them they came from my phone to my email then to my computer and then the easiest I could figure out was member photos because I didn't have the url for the pics just downloaded into computer
Old Apr 23, 2004 | 02:38 AM
Wow, you got me on that one. Looks to be late 40's or 50's but not sure. The fenders look home made, do not think thay are original. Grill looks cut off, like it was on a bigger truck. Just don't know. I have not seen door hinge mirrors like that since the early 50's. Mid 50's INternational trucks had a completely different cab, more rounded.
Old Apr 23, 2004 | 05:46 AM
bigfoot's Avatar
Urban Legend
Not sure but maybe an old Ih or a Waukesha. I think that they made some trucks back in the late 40s and 50s.
ddestruel
Apr 24, 2013 06:26 PM
Dodgezilla
Nov 6, 2011 04:13 AM
arbor x dad
Feb 14, 2011 01:56 PM
chariotdriver
Oct 18, 2008 10:50 PM
high country
Feb 28, 2005 02:32 PM
