need some carb help
need some carb help
I have a small tractor here with a 6hp wisconsin AEH engine on it, it has not run for a couple years , but before that it ran great. I have fire and compression , but i'm not getting any fuel into the cylinder.
It has a stromberg carb on it , that as of yet , i have been un able to identify , or get parts for.
any help would be appreciated here fella's
Jayme
Jayme
could be a clogged jet, shelack. Looks to old to have a solenoid on it. I've worked on them where there is a solenoid that turns off the fuel on them. It would have a wire or a terminal.
tear down the carb piece by piece. Clean and reassemble. Since it's small it should be easy enough. By doing this you probably free up whats clogging it. You can use low psi compressed air to clean any jets out.
Have done all that several times, it has not worked. Over the course of owning this tractor i have probably had the carb apart 20 times , completely, nothing looks broken, out of place , etc.
I'm looking for a rebuild kit at least, maybe it's just plain worn out, but i would like to find a complete NOS replacement...
Idaho Guy
Sep 20, 2009 10:02 AM
kingston
Feb 17, 2006 03:22 PM
kingston
33
Dec 7, 2004 05:31 PM
