Mig Welders
Old Mar 25, 2003 | 03:52 PM
tool's Avatar
Mig Welders
Hey anyone have any advice on Mig Welder purchase??<br><br>I'm looking at getting one for small jobs and repairs. I'd like to be able to weld as heavy as I can and stay 110 volt so I can use it anywhere. People have told me to go ahead and get one with a gas kit and stay away from Flux core???<br><br>How heavy will these units weld? Any advice?<br><br><br>Thanks.
Old Mar 25, 2003 | 04:18 PM
TXBobcat's Avatar
Re:Mig Welders
I believe Hobart makes a good machine. I have not used one of there smaller mig machines, but I have heard a lot of good things about them. For a 115v welder, check out http://www.hobartwelders.com/products/handler135.html<br><br>Personally, I would go with the Hobart 175, which operates off of 230v power. <br>http://www.hobartwelders.com/products/handler175.html<br><br>I think both are good machines for flux and solid wire.<br>Hobart also has a discussion board where you can see many peoples opinions of the above machines and others as well.<br>http://www.hobartwelders.com/mboard/<br><br>Whatever you do, I would recommend getting as much machine as you can afford. Just remember, with a gas setup, you will be pretty much confined to a shop because the wind will play havok with your weld, (i.e. blowing the shielding gas away).<br><br>It's better to have to much power than not enough. That's why I am getting a Cummins next time, instead of a gasser!
Old Mar 25, 2003 | 05:11 PM
geer's Avatar
Re:Mig Welders
I have the miller 135. Great little welder. If you bevel and get a good root pass you can weld pretty thick metal. Gas is the only way to go if indoors(shop). I have a 220v stick and the 110 mig. Have not touched the the stick ever since I got the mig.<br><br>Scooter
Old Mar 25, 2003 | 09:11 PM
AKDSLDOG's Avatar
Re:Mig Welders
I just happen to have a brand new Snap On Mig welder for sale! Never used! :'(.....**** impulse buy's. &gt;.
Old Mar 25, 2003 | 09:47 PM
dodgeman01's Avatar
Re:Mig Welders
[quote author=02DSLDOG link=board=10;threadid=12738;start=0#120435 date=1048648311]<br>I just happen to have a brand new Snap On Mig welder for sale! Never used! :'(.....**** impulse buy's. &gt;.<br>[/quote]<br><br>give us a price.<br>DM01
Old Mar 26, 2003 | 01:34 PM
tool's Avatar
Re:Mig Welders
I was flipping through a tool catalogue today and saw a Lincoln stick welder advertised. welds 40-235 amps and says it runs on 110V????? <br><br>Must be a misprint?<br><br>or do these things actually exist?
Old Mar 26, 2003 | 01:36 PM
tool's Avatar
Re:Mig Welders
My problem is I don't have 220-230 V power where I want to weld.<br><br>Otherwise I'd get a BIG sucker <br><br> ;D
Old Mar 26, 2003 | 01:55 PM
wheezer's Avatar
Re:Mig Welders
I used to work at a welding supply store. Like TXBOBCAT said, go with the Hobart. I would look into running 230v. It probably shouldn't cost too much. We sold a lot of the Handlers, mostly 110v's. I don't recall any complaints. Work very well on sheet metal up to about 3/16&quot;. Duty is a little low on heavier stuff, but if you are just making repairs or fabbing small stuff you'll be fine. Otherwise go for the Handler 175. They will run a 10lb spool and set up for gas. Some others aren't. Also, you will be able to get parts from a dealer. Some of the cheaper rigs leave you with no service. Probably the most important is look to see who makes the gun. I don't know if the Handlers still come with Tweco guns. The Twecos' work the best. Miller welders are good too. I don't know about Snap-on. I just know we sold probably 3 or 4 Handlers a month and never had a complaint.
Old Mar 26, 2003 | 04:11 PM
geer's Avatar
Re:Mig Welders
Miller comes with tweco.<br>Scooter
Old Mar 26, 2003 | 06:48 PM
trailblazenyj's Avatar
Re:Mig Welders
Maybe you could ask hoss who owns Hobart...<br><br>Anyway, pretty sure Miller bought them a couple of years ago to break into the lower priced market. I have a hobart 110 and it works pretty well. Wish I had the 175 amp machine though. A friend has one and it penetrates a lot better. Works pretty good off of a generator too when you don't have easy access to 220
Old Mar 26, 2003 | 08:45 PM
SjLingenfelter's Avatar
Re:Mig Welders
Yes there are 110v mig welders but the only thing i would use that mig on is littl estuff like welding straight pipe and stuff .SD03
Old Mar 26, 2003 | 09:00 PM
acoustic_axe's Avatar
Re:Mig Welders
A friend of mine has a couple of those hobart migs, 110volt, great little welder not sure on the model number. Weighs about 55 to 60 pounds. I took it on a job one time and welded part of the day with it, flux core wire, only jambed a couple times. I would buy one if i had an xtra 500 or so.
Old Apr 25, 2003 | 07:45 PM
Fishcop's Avatar
Re:Mig Welders
What do you guys think of the Craftsman mig welder? Who makes Craftsman?
Old Apr 25, 2003 | 08:02 PM
dieselcrazy's Avatar
Re:Mig Welders
i bought a hobart at the local tractor supply store ( love that place ) so far i really like it. im using the flux core wire so i dont need the sheilding gas right now... yes this is the same response i used in the 110 wirefeed welder subject.....good luck, scott
Old Apr 25, 2003 | 08:15 PM
Mexstan's Avatar
Re:Mig Welders
What are the pros and cons of flux versus solid wire? Costs, type of weld you can do with each one etc etc.
