How to remove silicon rubber?
Old Feb 6, 2003 | 03:44 PM
DEZLPWR's Avatar
Anyone know of a chemical or solvent that easily removes silicon rubber without damaging painted metal? I use silicon on my chronically leaky oil drain plug and always have a hard time removing it after each oil change. (using silicon is much easier and less expensive than replacing the oil pan!)<br>I don't like to scrape it too much for fear of scratching the oil pan and eventually causing rust....<br>I have heard that gasoline works well.....<br>Any other suggestions would be greatly appreciated!
Old Feb 6, 2003 | 04:21 PM
bulthisl's Avatar
Re:How to remove silicon rubber?
Starting fluid works great.<br>And you'll be happy while your doing it. ;D<br><br><br> : Eddie : 8)
Old Feb 6, 2003 | 04:24 PM
pappyman's Avatar
WD 40 mite work too
Old Feb 6, 2003 | 04:53 PM
FiverBob's Avatar
Automotive paint supply houses carry a product for removing silicon that will not hurt the paint.<br><br>Bob
Old Feb 6, 2003 | 07:41 PM
shortround's Avatar
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
Here is a thought from a beer infested, muddled mind.<br>A number of our deuce and a halfs and five tons have problems with the drain plug leaking. We've used copper washers between the pan and the drain plug. The copper is soft enough to forn a nice seal between the plug and pan and you dont have to worry about the silicon.
Old Feb 7, 2003 | 05:24 AM
pappyman's Avatar
Why not just get a quick drain plug from Geno's...this will end the need to take the drain plug out once its installed
http://www.genosgarage.com/
Nov 20, 2025 10:28 AM
ImpulseHydro
Oct 5, 2007 07:04 PM
Turbo6guy
Mar 21, 2006 12:20 PM
Strjock81
Apr 14, 2005 06:58 PM
