farmall tractor question
Old Jun 10, 2007 | 01:29 PM
RJ285's Avatar
I have at home a farmall super c that hasn't run in about a year. i have been trying to get it goin and have been having some trouble. I just rebuilt the starter and the distributor was replaced a few weeks before it got parked, new points and everything, but I don't think I have any spark because I pulled a spark plug, turned it over and couldn't see anything. I went through and checked voltage and I have roughly 5 volts going into the distributor but no voltage coming out. I went through and cleaned the contacts in the cap and the points. Still no voltage coming out of the distributor. Any thoughts? I'm not too big on gassers and I'm not sure what I should do next. Thanks for the help.
Old Jun 10, 2007 | 01:33 PM
clutch1's Avatar
do the point arc at all?
Old Jun 10, 2007 | 02:05 PM
dieselJon's Avatar
Take the distributor top off and spin the engine. My H had a after market distributor on it the replace the magneto, I sheared the gearing in it I bought a magneto and now it runs on 2 cylinders
Jon
Old Jun 10, 2007 | 05:09 PM
bigfoot's Avatar
Urban Legend
Jon
You must have bought a Magneto for a John Deer.
Old Jun 11, 2007 | 01:04 AM
farmer0_1's Avatar
make sure your points are grounding. you should have 12v at the points when open and when closed you shouldn't read any voltage it should be going to ground.
Old Jun 11, 2007 | 03:17 PM
RJ285's Avatar
Thanks for the advice guys. I'm going home this weekend so hopefully I'll get it running.
Old Jun 11, 2007 | 04:04 PM
dieselJon's Avatar
Naw, I have the fuel economy tractor. Shuts down 2 sets of valves
G1625S
May 21, 2007 02:01 PM
dodgeguy71
Feb 23, 2007 02:29 PM
G1625S
Jun 21, 2005 11:41 AM
