Explain this.
Old Jun 25, 2003 | 04:53 PM
SjLingenfelter's Avatar
Explain this.
OK Im lacking some information here. I thought Turbo Diesel's need higher compression pistons for better torque. Explain this to me please.<br>&quot;Turbocharged diesel engines must have low compression pistons in order to produce high horsepower. The lower the compression ratio the less wear on rod bearings and the lower the internal pressure will be when the injector fires. High internal pressure is very detrimental to the life of a piston. When you see a piston with a hole burned through, it's not the fault of the injector it is a result of internal pressure.&quot;<br> Excuse me if this is a stupid question but I had to figure it out.Thanks<br><br>SD03
Old Jun 25, 2003 | 04:57 PM
cp's Avatar
cp
Re:Explain this.
Total hogwash. Lower the compression enough and there won't be any wear on the lower end.<br><br>
Old Jun 25, 2003 | 05:04 PM
Mexstan's Avatar
Re:Explain this.
Lower the compression and compensate with a turbocharger to raise pressures.
[Edited by Moderator]
Old Jun 25, 2003 | 05:05 PM
phox_mulder's Avatar
Re:Explain this.
Where did you find that quote?<br><br><br>phox
Old Jun 25, 2003 | 05:24 PM
DieselDaze's Avatar
Re:Explain this.
Please be careful when writing a post or reply. <br>What you intended to say may not always be the way your post is interpreted by others.<br><br>Also, please keep the site rules in mind when making any posts!<br><br><br>Thanks<br>Rich.<br>
Old Jun 25, 2003 | 06:52 PM
Re:Explain this.
SD03-<br> When you're reading Bruce Mallinson's articles, keep in mind that they're aimed at big rigs, not pickup trucks. Those engines get worked a lot harder for a lot longer, and they need to hold together or the owner/operaters who run them will go broke. He's talking about 2000 ft/lbs of torque that lasts for a million (literally) miles.
dcwm
28
May 14, 2003 02:42 PM
MnTom
May 3, 2003 06:00 PM
RJMontana
Mar 21, 2003 11:20 PM
Dusty 96
Dec 8, 2002 06:40 AM
