chainsaws
Old Apr 8, 2006 | 09:34 PM
rico334's Avatar
chainsaws
Just a quick question. I bought a Coleman Ultra 2500 generator to keep in my travel trailer for emergencies. While I was at it, I also bought a small electric chainsaw for cutting firewood as needed.
Anyone know if the oil that goes in the reservoir for oiling the blade is the same thick stuff that a regular gas engine chainsaw uses for its blade oiling?
Thanks,
Old Apr 8, 2006 | 09:35 PM
sherod's Avatar
Yup, just plain bar oil. When I run out, I use old motor oil mixed with STP. Never had a bar burn out yet.
Ed
Old Apr 8, 2006 | 10:32 PM
kandgo's Avatar
My elect pole saws take 30wt motor oil, found out the hard way when burning up chains and bars,then read the manual.Goodluck,,Rick
Old Apr 8, 2006 | 11:41 PM
White00's Avatar
I always use sae30. It flows better in cold temps and is cheaper than bar and chain oil.
Old Apr 9, 2006 | 01:35 AM
jaconst's Avatar
bar oil is just sae 30 sometimes with a little color added and sometimes a name
Old Apr 9, 2006 | 11:31 AM
Fronty Owner's Avatar
I usually use 30 wt on mine. Occationally I grap a few gallons of 90 wt or 140 wt from work since its free.
Old Apr 9, 2006 | 01:04 PM
03 ant a hemi's Avatar
Most of your bar oils now are vegey oils for enviromental reasons. At least up here in Canada they are.
I usually run a no name oil or buy a gallon of canolla and use it. Sure smells nice.
Old Apr 9, 2006 | 03:32 PM
EClancy's Avatar
when i worked up the stone quarry, i would take used 80/90w home to use when cuttin firewood.....worked good, and best of all was free
Old Apr 9, 2006 | 05:49 PM
wheelo90's Avatar
Am I the only one who buys the bar and chain oil?
It only costs around 2.00 a gallon (in Bulk).
I have not had any real problems in the winter time.
Old Apr 9, 2006 | 06:28 PM
Dieseldude4x4's Avatar
You're not the only one. I run three different Stihls and I use only the bar oil. I've got almost $1600 tied up in three saws and spare chains and I'm not going to chance tearing up a bar or chain. The difference between real bar oil and the stuff most people run is that the bar oil has an additive to make it sticky/stringy. The real stuff has strings on it like pizza cheese when you pour it in the saw and stop the flow. Course, this is just me too. Maybe I'm too picky.
Old Apr 9, 2006 | 06:33 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I use amsoil rear gear oil.
Old Apr 9, 2006 | 07:50 PM
DSjockey's Avatar
Old crankcase oil or the cheapest 30 wt I can find
Old Apr 9, 2006 | 08:34 PM
kandgo's Avatar
I would suggest to read and do what the manuals state, I use only bar oil in my stihl chainsaws, the pole saws recommend 30wt oil, they are made by deca,and I think why they use motor oil is it is thinner and most pole saws I have seen you have to manualy pump up the oil resovoir to get the oil to go to the bar which is straight up in the air and needs to be thinner and pressurized. At least that is what my pole saws manual states. I am with Dieseldude on the stihl bar oil as I too have some money tied up in the stihl equipment and have always used the thick bar oil. Goodluck,,Rick
Old Apr 10, 2006 | 07:50 AM
Why would I pay $800 plus for a saw and run 25 cent oil in it? I don't know.
On another chain saw note, I put a skip tooth chain on the 440 last weekend and let me tell you what, that thing will flat eat. Anyone else using them?
Old Apr 10, 2006 | 10:47 AM
Redleg's Avatar
$5 a gallon for husky oil... motor oil is almost that, a quart now. I wouldn't use old oil, you'll wear out the pump, don't ever let the sump run dry long either. I even try to wipe off the saw dust around the cap before filling, so it doesn't go in an contaminate the pump. How many lube thier bar-tip and clutch bearings? I do it every time I change the chain, at least.
