Caddy Shack revisited...darn moles!
Old Jun 25, 2005 | 05:37 PM
BEHRMAN's Avatar
Originally posted by msilbernagel
I've foud a battery powered stake -- thing is about a 'D'-cell in diameter and a foot long. It makes clicking noises on some random interval, and evidently irritates the moles enough where they leave.
Put the battery in, drive it into the soil mostly.
Gophers hate the noise and move elsewhere.
When he moved to the side yard, I moved the stake.
Never saw him again.
Found the thing at the local Fred Meyers a few years back. Ace may have them too.
First thing I've found that works as well or easily.
FYI - Mark
Forgot to say....I have 4 of those electonic stakes. They are all spread throughout my 1/3 acre lot.
Old Jun 25, 2005 | 05:43 PM
Redleg's Avatar
Wonder if that would work on chipmunks?
Old Jun 25, 2005 | 05:45 PM
BEHRMAN's Avatar
I don't mind the chipmunks and squirrels because I can see them. If I can see them, I can remove them.
Old Jun 26, 2005 | 04:39 PM
jrs_dodge_diesel's Avatar
How bout a couple little critter shaped C4 charges, ala Caddyshack style.
Seriously, there was a device a I saw here a while back called the Rodenator. Its a pipe with a hollow cork (best I can describe it) that you shove into the hole. The other end of the pipe has a hose that hooks to a LP gas tank. You open the valve and flood the tunnels with the gas. Turn the valve off and hit the ignitor. Shock wave usually kills them, and collapses most tof the tunnels. Click the link below for more info.
http://www.rodenator.com/
Old Jun 26, 2005 | 05:10 PM
BEHRMAN's Avatar
OK... Hooked a 100 ft garden hose to my tail pipe today. I fumagated several main holes with the sweet taste of warm diesel exhaust. I was able to create enough pressure into one hole to come out of holes over 50 ft away. I then plugged holes as they were leaking, hoping to pressurize and fill as much of their network as possible. We'll see what happens. Is this in-humane?
Old Jun 26, 2005 | 05:27 PM
spunbearing's Avatar
hey if the critters can't take a little smoke it isn't your fault! haha
Old Jun 26, 2005 | 05:36 PM
BEHRMAN's Avatar
So which is better (deadlier)? The tail pipe from my Cummins or the one from my Hemi.
Old Jun 26, 2005 | 06:18 PM
Hemi Dart's Avatar
Talking
Is the HEMi a 426? If yes it will probably run fat at idle. This might work better.
Old Jun 26, 2005 | 07:04 PM
The gas engine. The gas engine produces CO (carbon monoxide) which can kill you (think idling car in garage). The diesel engine produces virtually no CO. Although both engines produce CO², and in cofined area could aspyxiate you. RUn the gas engine into the hole, and get .22 and pop the ones that come scampering out.
Old Jun 26, 2005 | 07:54 PM
12PACK's Avatar
What are those little varmints preditor? Coyote's, foxes, ect? Would getting some coyote urine and spread it around help? I believe it's sold in some stores but not sure where. This might be the easiest, but not necessarily most enjoyable, solution. Just a thought.
Old Jun 26, 2005 | 08:10 PM
BEHRMAN's Avatar
No...it's a new 5.7 Hemi. I guess I could run it at 5000 RPM for a while!
Old Jun 27, 2005 | 10:30 AM
BEHRMAN's Avatar
Update. After a 1/2 hour smoke out yesterday.....I awoke to find no new traces of activity! Is this just coincidence or does diesel exhaust really work?
Old Jun 27, 2005 | 10:34 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Is this in-humane?
One would certainly hope so
Old Jun 27, 2005 | 11:12 AM
ramlovingvet's Avatar
DTR'S Chaplain
I must add that I have had 100% sucess with a few old Claymores.
Old Jun 27, 2005 | 12:18 PM
Admin Team Leader
Makes note to never show up un-announced at ramlovingvet's place
