Which AR-15?
Which AR-15?
I have the chance to buy either. I wish I could afford both.....maybe I can. But, if I can't which should I get? Thanks.
AR-15 H-bar, Flat Top, 2 Mags, Ammo $775
Bushmaster Vmatch 24" AR15, jarred trigger, very accurate, $800
I believe you will save even more money by piecing it out and building it yourself. My bro-in-law builds his own ARs and he wouldn't have it any other way. They are sweet, he loves them more than himself. They are all decent quality virtually all the same so don't be fooled by the high priced namebrands, it will be the same gun. JMHO Of course if these are used guns you are looking at and they are closely availabe I guess it wouldn't hurt, but the bond should be solid between man and gun. You feel better when you know it was a gun you built and it rocks!
You aughta get new for those prices or less if you order the uppers and lowers seperate. A whole, new gun averages a couple hundred more qualifying it for an excise tax.
I didn't read all the posts, but if you can find an off the shelf rifle that is EXACTLY what you want go for that. otherwise I would build. Most of your kit gun companies will customize a kit to what your wanting.
The V match barrel is heavy. If you are going to get the 24" V match you better budget in a shooting bench too, cuz it's a bench gun.
If the H Bar is all Colt buy it. Colts do and always will cost more money.
Quick price break down.
Lower receiver $125.00
Lower parts kit 70.00
Stock 70.00
Upper assembly 500.00 to 2000.00
Scope mount/rings 30.00 to 225.00
Scope 70.00 to 2000.00
Trigger upgrade 10.00 to 250.00
If you can change the spark plugs in your CTD you can put an AR together.
Yes I know there aren't any spark plugs that's how easy it is.
Stock 70.00
Stock 70.00
Stock 70.00
I put many M-16's together in the Army as that's all we had. I carried a 1911 for a side arm too as a TC on a recovery tank when I was attached to a cavalry unit.
If you can find a way to get on the gun-forums.com site, look at this thread:
http://www.gun-forums.com/showthread.php?t=1369
It goes into serious detail about AR-15's.
I suppose he already sold it.
