Any Termite guru's?
Old Sep 8, 2009 | 01:53 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Any Termite guru's?
I was replacing a sliding door this weekend and found some active termites Seems the guy who installed this door in 76 needed 1/2" higher threshold to mount the existing door, so he put a small piece of plywood over the treated wood that was there.
This plywood piece not being treated and on ground level was about 25% destroyed by termites and the treated lumber under it was scarred but you could tell they did not want to eat it.
Obviously I put treated lumber back down there but now I am worried that I only found a small part of the colony or colony's. I recently re insulated the crawlspace under the house and NO sign of termites at all. this is the first sign I have seen of them and I live in the woods with food for them everywhere around the home.
My bet is i need to bring in a specialist to tackle this correctly but I am worried about getting ripped off. I had a guy try to tell me years ago that he found them in the crawl space and I needed to sign a contract right away. When i asked him to show me where he clearly did not want to show me.
He assumed I would not crawl down there and look and I made him do so and there was NOTHING where he said there was. Needless to say he left in a big hurry.
Any suggestions on what I should or shouldn't do?
Old Sep 8, 2009 | 01:57 PM
chaikwa's Avatar
A good hot fire will generally eradicate any termite problem. At least that's been MY experience.
Don't mention it, glad I could help.
chaikwa.
Old Sep 8, 2009 | 01:59 PM
Admin Team Leader
chaikwa.
Do you use seasoning salt on the termites before you toss them in a pan?
Old Sep 8, 2009 | 02:00 PM
chaikwa's Avatar
NO! Salt, ANY salt, is bad for you. And I don't use a pan neither. Just fry 'em where they live.
chaikwa.
Old Sep 8, 2009 | 02:07 PM
Blake Clark's Avatar
Id find as many live samples as I could and send em to Kalamazoo, overnight delivery too.
Old Sep 8, 2009 | 02:46 PM
chaikwa's Avatar
Is that meant to imply they'd do some damage here? Most everything here is made of metal... I'm a welder! "Wood is good, but steel is real"!
chaikwa.
Old Sep 8, 2009 | 02:52 PM
Admin Team Leader
The reason trees are made out of wood instead of metal is to keep the Woodpeckers from driving you crazy
Old Sep 8, 2009 | 02:58 PM
I'm a welder!
Huh? No Im a welder....
Ive only seen you post pics of a sawmill with a really small garage!
Therefore I must conclude you are a lumberjack....
Now Im gonna stop before Lary get mad cause we high-jacked his thread with the usual high-jinks.
Sorry Top,
Really not to sure what to do with the termite situation other than call a professional. Not sure how well a home treatment with something like malathion would work.
chaikwa's Avatar
But if they were made from steel then woodpeckers would be steel peckers and they'd peck steel and we wouldn't think any more about it than we do when woodpeckers peck wood.
chaikwa.
Old Sep 8, 2009 | 03:01 PM
chaikwa's Avatar
Correction; you USED to be a welder. REAL welders keep up with tek... tecnoloj... techknawlajee... keep up with the times and forget about the stick stuff!
He did. He called on ME. And I gave him the solution.
chaikwa.
Old Sep 8, 2009 | 04:20 PM
rebal's Avatar
Not to high jack the tread ..but you could buy them plastic termite stakes with treated cardboard in side them that you drive in the ground. workers take them home and it kills the colony (so they say)
I was down in mexico a few years back and found chloradain in a big ol bottle and brought it back home it will kill them suckas for ever and ever and ever and so on
Old Sep 8, 2009 | 06:55 PM
ramlovingvet's Avatar
DTR'S Chaplain
I once was told a way to get rid of Critters on the body.. I am sure you were told about it Top. maybe it will work on a larger scale?
Old Sep 8, 2009 | 07:04 PM
Hvytrkmech's Avatar
I asked a buddy whom is an exterminator. He stated that they start at ground level and work their way up. Any wood that has ground contact is subject to invasion and is a suspected point of entry. If you have no wood/ground contact then look for mud tubes going from the ground up the foundation to a section of wood. Termites hate concrete and will not crawl across it, hence the mud tube. He also stated that over the counter homeowner chemicals are to regulated to be a proper fix. If you have an infestation you should use a professional.
I have a log cabin, so my buddy comes twice a year and does the whole house inside and out.
Good luck with this, I hope you found them in time.
Old Sep 8, 2009 | 10:08 PM
Admin Team Leader
My home is brick and no tubes any where, only sign of them was the small 1/2 thick piece of plywood the door installer laid on top of a treated 2x4 under the door sill. This is directly off my concrete patio and they would have had to follow a crack along side it or tunnel to it under the slab.
Just insulated the floor under the house and checked every inch of it, no sign of any kind and wood is rock solid. Any untreated wood is at least 10 " off the ground on top of concrete block and most is a lot higher than that.
Thanks for the heads up
Old Sep 9, 2009 | 08:18 AM
j-fox's Avatar
My BIL had a all brick house that was nearly destroyed by termites.
They came in on a steel beam supporting the floor above the basement.
There were terrible to rid.
A 10% solution of kerosene with the chemical finally did it.
Off topic, everytime I see a story on termites, I think of my old Lab. " Spout". She hated them. She could walk into any house and find them (if there are any) in just 3 minutes!!!!!!! I should of gone on TV with her and made some extra money.
