97 corolla help, oil in spark plug hole
Old Nov 17, 2007 | 02:09 PM
mr T's Avatar
hey guys, noticed some oil coming out of my cylinder 1 spark plug cable vent hole, then i noticed that my hole where the spark plug goes is flooded with oil, car runs fine despite this, but what could be causing this? ps corolla has 241k
Old Nov 17, 2007 | 02:59 PM
vzdude's Avatar
DTR's 'Go to Guy'
Vlave cover gasket. There is an o-ring type gasket under the valve cover that seal out the oil from the spark plug tubes. Usually the new gasket comes with 4 of these o-rings. Fairly easy job to do.
Old Nov 17, 2007 | 03:35 PM
stumpjumper's Avatar
ditto, on the seals for the valve cover/spark plug hole gasket...
Old Nov 17, 2007 | 05:12 PM
mr T's Avatar
thank you boys...i got it done already, not a bad job at all...even got a look at the timing belt in the process, still looks good
tool
Jan 21, 2008 11:52 AM
dodgezilla04
Sep 6, 2007 03:49 PM
dieselrob
Jan 23, 2006 12:04 PM
