"6 bent wheels" update: fixed
Old Jul 23, 2007 | 11:25 PM
ChargerLighting's Avatar
Thumbs up "6 bent wheels" update: fixed
A while back I had a vibration in my '95 dually at 70-75mph +. I took it to Belle Tire (mistake) where they re-balanced my wheels & told me all 6 were bent ...causing my vibration.
Like an idiot, I believed them , but didn't buy anything (luckily).
I talked to the previous owner of my truck & he said he had those same wheels on his '99 Ram dually & they did NOT vibrate at all.
So, yesterday, I was checking the underside of the truck & noticed I could push the driveshaft up/down in the center support bearing. My old man took it upon himself to dis-assemble, buy the parts & fix the truck himself while I was at work. The center bearing ended up being toast & a dealer only part to the tune of about $100. He also got the rear u-joint replaced while things were apart.
I took it on the freeway after we stuck it all back together, vibration is gone, even at 90mph
This Belle Tire is beginning to aggravate me...all I wanted was my truck fixed. I can't stand it when people/places will just try to sell you something & ignore the main problem. Then again, they don't care if you spend $5000 to fix a $50 part.
Old Jul 23, 2007 | 11:51 PM
westcoaster's Avatar
They sure do care (about thier pockets), that's why they are trying to sell you the $5000 dollar part for the $50 fix....
Old Jul 23, 2007 | 11:57 PM
bsj04's Avatar
mine has a little vibration and i just got new wheels and tires becauce i wanted to but my carrier bearing does havce some play in it. maybe like 3/4 inch. it looks likr the rubber is wore out. is that to much play?
Old Jul 24, 2007 | 02:29 PM
Pooter's Avatar
Did you shim it down any?
Alot of guys are having luck shimming the carrier bearing down 1/2" - 1", helps with some of the vibration some guys are having.
I think I actually have some spacers for it too, from the superlift kit, let me know if you need them.
(Not hard to make, I know, but shoot, theyre already cut/drilled and fancy non-rusting coated)
8Lug_hotrod
Apr 18, 2021 08:07 AM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
ChargerLighting
Jul 5, 2007 10:32 AM
DAYTRIPPER63
Feb 28, 2006 12:11 AM
jwtuc
14
Mar 22, 2004 08:35 PM
