2 Speed Rear Axle
Old Jan 17, 2011 | 09:36 PM
dott's Avatar
2 Speed Rear Axle
Maybe this is crazy, but it's rolling around in my head and can't shake it until I investigate.
My '04 Dodge has the AAM 11.5" rear axle with 4.10 gearing and NV5600. It's great for towing. If I never did anything but tow, there would be no issue. Driving unloaded is a pain. To get the best mileage, I have to drive 55-60 mph. I don't want to re-gear (to say 3.73) because it's a standard and the towing would be hosed. Also, backing up is already a little fast, even with the 4.10 gears. Currently running stock size tires.
My crazy idea is to find a 2 speed axle with close to desirable gearing, probably adjust it with tire sizing, then find a way to install it.
Already looked at the Gear Vendors boxes but they are a little pricey and kinda set a budget for any other mods.
Do all vehicles with 2 speed axles use air brakes?
Here is some axle data I found:
GM H15 - Rear Axle
Capacity lb.(kg) - 21,000 (9,526)
Available Ratios (to 1) 3.55/4.83, 3.70/5.05, 3.90/5.32, 4.11/5.61, 4.33/5.91, 4.56/6.21, 4.88/6.65, 5.29/7.21, 5.57/7.60, 6.14/8.38, 6.57/8.96, 7.17/9.77
Ring Gear (pitch dia.) in.(cm) - 16.5 (41.9)
I've heard that the GMC/Chevy Topkicks have a two speed rear as an option. Haven't been able to find any info on this.
It seems like U-Haul trucks would be a good place to look.
I realize there would be a lot of fabbin' to get this to work. I just want to look at the basic stuff first to see if there is any chance of it working.
Any suggestions are appreciated.
Old Jan 17, 2011 | 09:41 PM
dott's Avatar
Just found this about Topkicks regarding hydraulic brakes:
"The rear axle has a 13,500-pound capacity and two-piston disc brakes."
and
Rear axle ratio, 4.30 - 5.13 available on:
Regular Cab/Crew 2WD
Motor Home 2WD
Commercial Cutaway 2WD
but, that ratio is going the wrong way.
Old Jan 18, 2011 | 07:07 AM
chaikwa's Avatar
All the 2 speed axles I've seen are almost too big physically to get under a one ton truck. No, they're not all air brakes but I don't know what would have to be done to get your brake system to work with the system on the 2 speed axle. I'd have to think the brakes, lines, cylinders etc., would all be much bigger and I don't know if your master cylinder would work. If you changed your master cylinder, I don't know what would happen to your front brake system. And if you changed the braking system on the new 2 speed axle to something your existing master cylinder would work with, I don't know if they'd be effective.
U Haul trucks typically don't use 2 speed axles because people tend to tear them apart due to not knowing how to correctly use a 2 speed in the first place.
Anything can be done with enough time and money tho!
Old Jan 18, 2011 | 05:57 PM
annabelle's Avatar
I looked at an 86 (?-not sure of exact year)Ford dully that had a two speed rear axle.
Old Jan 18, 2011 | 07:32 PM
12valve@heart's Avatar
I recall a mid-70's Ford school bus that used an electric solenoid to shift ratios and used hydraulic brakes. Since the new trucks come with 20" tires already, putting a set of 20's from a bus under there shouldn't be any problem. Oh yeah, aspect ratio.
Old Jan 18, 2011 | 08:05 PM
chaikwa's Avatar
Does that change when you shift the rear end?
Old Jan 20, 2011 | 05:38 PM
Depends on what RPM you shift at. High enough RPM and the aspect ratio increases as the tire grows (think top fuel).
Old Jan 20, 2011 | 08:17 PM
chaikwa's Avatar
That makes sense in a scary kinda way!
Old Jan 20, 2011 | 09:35 PM
dott's Avatar
Thanks, y'all. I know it's a crazy idea, just thought I'd ask.
Old Jan 21, 2011 | 11:12 AM
olddodgetrucks's Avatar
Not a stupid idea,had a 70s i.h.c. one ton,gooseneck special ,392,5 spd ,2 speed rear axle with std 8 bolt one ton wheels.
nvr-enuf
Jan 30, 2014 06:56 PM
West Coast
Big Rigs
Jun 10, 2013 11:57 PM
NoFrills
Mar 29, 2009 06:03 PM
granahan378
Feb 25, 2009 01:58 AM
MX429
Aug 20, 2006 06:41 PM
