1952 Ford 8N Steering
Old Sep 10, 2006 | 01:21 PM
dodgeguy71's Avatar
So I went over to a guys house today to check out his 8n. It seems his steering went out a couple days while bush hogging. Here is the problem and as soon as I get my truck back I am gonna tote it back to the shop.
You turn the steering wheel to the right and you can feel resistance and then you can turn the wheels to the right. As soon as you stop and go to the left the steering wheel and shaft start to rise out of the steering column until you reach a certain point and it stops. I'm guessing by the pictures I found at another site the gear on the steering shaft is hitting the top of the box. I read over at the other site about a nut that comes loose??
Just looking to see if anyone has messed with one. Someone who could give me a difficulty rating on rebuilding the steering gear. I've rebuilt CAT hydraulic pumps for 3(almost 6 years on all) years, CAT engines, transmissions, cylinders, differentials....you name it, I've probably rebuilt it(CAT's at least). So do I have the skill to rebuild this gear without a manual or are there some specs I would need to know about? Thanks for any info guys!!
Shawn
Old Sep 10, 2006 | 04:04 PM
ftltmp's Avatar
check out this site www.dennie-carpenter.com they make every part you might need. I know I have an 8n myself. i hope this helps.
Old Sep 10, 2006 | 06:19 PM
MOAGGIE's Avatar
That is a pretty complete catalog! Wow, I found some parts I have been looking for awhile. 8N is a great little tractor but when something goes wrong with them it is usually expensive!
Pele
Cummins Conversions
May 21, 2014 06:49 AM
GasganoFJ60
Dec 17, 2008 08:30 AM
dodgeguy71
Feb 23, 2007 02:29 PM
Matt Lambrech
Jan 9, 2007 06:08 PM
