110 wire feed welders
Old Apr 24, 2003 | 04:11 PM
bigredbrick's Avatar
I'm looking for a wire feed welder and want some input on what is good and what to avoid. This will be used for &quot;hobbying&quot; not for business/production heavy use.<br>I've been considering a Lincoln MigPac 10 but wonder how much for a gas bottle.<br>Thanks, Chris
Old Apr 24, 2003 | 07:26 PM
geer's Avatar
Re:110 wire feed welders
I have the miller 135 with the shielding gas. I love it the bottle lease is the expensive part. I did a life time lease and it was about 200 dollars. You get 100 back when you turn in the bottle. I think Lincoln, Hobart, and Miller all make good machines. I got the free cart with the Miller. I like the way the wire feed is also.
Old Apr 24, 2003 | 09:48 PM
rich's Avatar
I have a miller also that i run with my big miller welder just keep an eye on the duty cycle on the one you decide to get
Old Apr 25, 2003 | 07:33 AM
TXBobcat's Avatar
Take a look at this thread:<br><br>http://www.dodge-diesel.org/yabbse/i...threadid=12738
Old Apr 25, 2003 | 07:46 PM
Fishcop's Avatar
Who makes the Craftsman mig welder? Is it any good for light duty?
Old Apr 25, 2003 | 07:59 PM
dieselcrazy's Avatar
i bought a hobart at the local tractor supply store ( love that place ) so far i really like it. im using the flux core wire so i dont need the sheilding gas right now...good luck, scott
Old Apr 28, 2003 | 08:58 PM
Agades's Avatar
if you have a 220 outlet <br>stay away from the 110 units<br>you wont like them if you have to do any real welding <br><br>real welders use stick and tig
Old Apr 28, 2003 | 10:07 PM
geer's Avatar
You can weld thick metal with a 110. I work at a mine where we run 480 volt welders. The point is we multi pass with those as a person might multi pass with a 110. You have to be doing alot of welding to need a huge duty cycle. If your not sure what duty cycle is than you probably don't need a bid welder. I have built several trailers with the 110 with no trouble.
Old Apr 29, 2003 | 12:31 PM
Nuttymopar's Avatar
Check out www.Northerntool.com<br><br>Some of there prices are not too bad and plenty of things other then Welders.
PROSOUTH
31
Dec 17, 2005 12:09 AM
billyrae
37
Apr 27, 2005 10:41 PM
RBFD415
Oct 3, 2004 08:55 AM
TPilaske
16
Nov 22, 2002 08:15 PM
