Ok Diesel Doctors.....
Old Mar 29, 2012 | 07:28 PM
Gudfshn3's Avatar
Ok.....about a month ago my truck threw DTC P2146 (Fuel Injector Group A Supply Voltage Circuit Open). I was in a parking lot and it ran rough for about 5 seconds and that was it. I cleared the code with my Superchips Flashpaq, which at that time was set on Performance Mode. After running perfect for 1 week, I started the truck early in the morning. It started and idled perfect, but died after about 5 seconds. It did this 3 times before I decided to drive the wifes car for the day. After sitting in the driveway for the day, I got home and it started right up. Idled and ran perfect. I programmed the truck back to STOCk and sold the programmer. Now, for the past couple weeks, when I start the truck in the morning it acts like it wants to die while idleing. It starts great and idles great for about 4-5 seconds, but then begins to die but quickly recovers itself and keeps idleing. It has died a few times, but I do get it restarted. Yesterday it gave a code after dying, P0341 (Camshaft Position Sensor Performance/Rationality). Below is a couple videos of it starting and chokin in the mornings. One thing to note......batteries are original and I have NO issues when starting and driving the truck after work when its warm!! Any ideas?!?! Could it be weak batteries and the truck tries to die when the grid heater cycles?!?
http://www.youtube.com/watch?v=b_BO8...hHV0RNsg_nmZkw=
http://www.youtube.com/watch?v=jqd3t5VPwe0
Old Mar 29, 2012 | 07:52 PM
06RAM2500's Avatar
Couldn't tell ya where the cam sensor is, but if that's the only code you had show up, then it's obvious it's a bad sensor, wiring issue, or the ECM.
INJECTOR DTC’S PRESENT
OTHER DTC’S
CAMSHAFT SENSOR
(K44) SIGNAL CIRCUIT OPEN
(F855) 5-VOLT SUPPLY CIRCUIT OPEN
(K916) RETURN CIRCUIT OPEN
(K44) SIGNAL CIRCUIT SHORTED TO GROUND
(K44) SIGNAL CIRCUIT SHORTED TO (F855) 5-VOLT SUPPLY CIRCUIT
(K44) SIGNAL CIRCUIT SHORTED TO (K916) RETURN CIRCUIT
(K44) SIGNAL CIRCUIT SHORT TO VOLTAGE
ECM
INTERMITTENT CONDITION
If the batteries were that bad, you would be throwing other codes as well.
Old Mar 29, 2012 | 07:55 PM
cincydiesel's Avatar
Sounds like an electric gremlin.. Check this out: https://www.dieseltruckresource.com/...re-t81936.html
Found this very same problem on my truck that was causing the truck to randomly shut down while cruising down the highway. Ended up being a short.
Old Mar 29, 2012 | 08:26 PM
Gudfshn3's Avatar
None of the pictures are showing up from that original thread. This will reallys show how dumb I am when it comes to this stuff....but where exactly is this wire and where is my AC compressor?!? I do change my own oil, so I know where the oil filter is!!!!
Old Mar 29, 2012 | 08:35 PM
Let me see what I can dig up.. The ac compressor is on the passenger side of the engine compartment at the bottom just behind the radiator.
Old Mar 29, 2012 | 08:44 PM
https://www.dieseltruckresource.com/...5&ppuser=26903
This picture is from the bottom side looking up directly at the oil filter.
Old Mar 29, 2012 | 08:50 PM
Gudfshn3's Avatar
Oh Ok....WOW....so those little tiny nicks in the wire coating were causing some issues?!!?
Old Mar 29, 2012 | 08:58 PM
Especially if they are close to metal or any other means of grounding
Sent from my DROID BIONIC using Tapatalk
Old Mar 29, 2012 | 10:44 PM
Gudfshn3's Avatar
Well, I have an appointment to take the truck to the mechanic Monday morning!! I REALLY dont want to do this, but I have no idea where to start!!! Any other ideas or suggestions are greatly appreciated!!!
Old Mar 30, 2012 | 09:32 AM
Let us know what he finds.. Hopefully its a quick easy fix
Old Mar 31, 2012 | 03:19 PM
Gudfshn3's Avatar
Well, checked all my wires and they are all good! I went to Autozone this morning, and had my batteries load tested......turns out both were shot!!! Bought new batteries and I pray this was the culprit!!! Im still taking her in to the mechanic Monday to get checked out....keepin the fingers crossed!!!
Bschwarzli
ONDTR #39
Oct 22, 2009 04:53 AM
Bschwarzli
Sep 26, 2009 09:48 AM
bullfrog5.9
ONDTR #39
May 9, 2009 11:44 PM
Mexstan
Jun 29, 2008 05:31 PM
daking
ONDTR #39
Mar 31, 2008 07:29 AM
