Off Road / 4x4 OffRoad discussion, along with 4x4 events and information.
Tallest Lift?
Old Sep 15, 2006 | 02:10 PM
Txwelder's Avatar
Tallest Lift?
How big can I go on a 96 before I have to buy new drive shafts and start worrying about pinion angles? I was looking at 5" but dont know if I will run into problems with it. Thanks.
Old Sep 15, 2006 | 03:50 PM
Gotlift01's Avatar
A 5" you will be ok.....no driveshaft mods to do. Just make sure that your lift comes with a pinion angle shim to keep that driveshaft straight and you'll be just fine!!
~Nick
Old Sep 15, 2006 | 03:57 PM
BigBlue's Avatar
I'm running a 4.5" with no issues. And I've got a one piece driveshaft on the rear. Like Gotlift said, just make sure the lift comes with the shim to rotate the rear axle upwards to keep the pinion angles in line.
Old Sep 15, 2006 | 11:28 PM
Txwelder's Avatar
So no issues with most 5 inch lift kits? Just curious about what I really have to do to install the kit.
Old Sep 17, 2006 | 02:34 PM
Jambbii's Avatar
With my combo, singlecab I ran 9" of lift with no problems.
Old Sep 18, 2006 | 01:04 AM
XLR8R's Avatar
Don't you have a 2-piece driveshaft?
I'd definitely shim the carrier bearing properly, if I were you.
I can get enough lift out of the 5K# airbags to feel the U-joints in 1st & 2nd, so I made a half inch aluminum spacer in the shop to bring the driveline angle back to spec.
Old Sep 18, 2006 | 05:29 AM
Txwelder's Avatar
Yes I do have a two piece rear shaft. I would love to get rid of it but will probably just shim the carrier like you said. Your half inch spacer was good for a five inch lift?
Old Sep 18, 2006 | 07:18 AM
XLR8R's Avatar
The airbags at 100psi lifted the frame over the rear axle 4" when the truck is normally loaded (about 10K#), so the carrier bearing was about 3" higher. 60psi still put the bearing high enough (about 2") to feel the U-joints, and 40psi they were still happy. The half-inch spacer kept the driveline angle good up to 60psi, which was about a 2.5" lift - I keep them at 40psi to keep the stock empty ride height with the 2K# of tools, equipment and parts that are always on the truck.
I would think that a 5" lift needs to have the carrier bearing shimmed at least 1", I'd go 1.5" for sure if the truck was empty.
Old Sep 18, 2006 | 08:34 PM
Lsufan78's Avatar
i'm pretty sure that most of the "kits" come with a shim for th e 2 piece drive shafts...
later, dustin
Old Sep 18, 2006 | 09:15 PM
XLR8R's Avatar
I should think they'd have to; but are they carrier-bearing spacers or rear-axle shims?
Old Sep 19, 2006 | 06:04 PM
Gotlift01's Avatar
Ahh I forgot about you having a long bed.....yeah you will have to shim the carrier bearing down which is a piece of cake!! I made my own bracket for my powerstroke using some 3"X3" hollow square tube steel and drilled some holes and bolted it back in......worked like a charm.
And with the shims on the axle and moving the carrier down....you'll have no issues and won't have any need to get a new shaft.
~Nick
rattlbox
Mar 17, 2010 10:03 PM
SkyHarborCowboy
Sep 25, 2005 10:12 AM
lucey
Apr 21, 2005 09:53 PM
cummins1279
Sep 21, 2003 07:04 PM
I PASS GAS
Aug 13, 2003 04:31 PM
