NJ gtg
Old Jun 17, 2007 | 08:44 PM
  #706
Juniorphil's Avatar
Might try to make it, i don't think sticks will be in been busy but you never know
We could alway go to riverdale armory also little closer to Pat, Maike and a few others?
Pat what is info for stuff up by you?
Old Jun 17, 2007 | 09:51 PM
  #707
ohyeahfriday's Avatar
Pretty simple, given nice weather. Thursdays are bike nights, they should be getting into full swing sometime soon. Friday nights and usually Saturdays as well are car shows. This is all @ The Chatterbox, it is a old style drive in restaurant, they used to do the rollerskating waitressess, but due to incompetence had to quit. Easy enough to get to/find. At the intersection of routes 15/565/206.
I will look into the Riverdale idea
Old Jun 18, 2007 | 04:40 PM
  #708
mikmaze's Avatar
Pat, if ya ever need help keeping the herd numbers down, lemme know, I am good with the bow, shotgun or muzzleloaders !
Old Jun 18, 2007 | 07:37 PM
  #709
Patriot2500's Avatar
Riverdale sounds good, maybe next week?
Old Jun 18, 2007 | 10:41 PM
  #710
I might try to make that one @ riverdale.
Truck is currently @ the stealers, see how they make out with it, hopefully get the white smoke straightened out, maybe the DW too, that'd be fancy...
g/f will be down this weekend, pretty sure I am going to hit the car show Saturday early evening(likely sometime between 5-7) up here, see what kind of activity they have.
Old Jun 19, 2007 | 05:04 PM
  #711
Juniorphil's Avatar
if i make it tomarrow will not have sticks in, HO has been borrowing the truck longer than expected(They can't get his bearing out)
So maybe next week they wil be in.
Old Jun 19, 2007 | 06:02 PM
  #712
atc250r's Avatar
Originally Posted by ohyeahfriday
Yupp, thought about a coupling, but figured there was no way, gonna try a shorter run of tubing my brother got with his Autometer boost that we did not need.
Most hardware store have 1/8" compression fitting unions just in case you end up needing it. If you're still in a bind and want to take a ride over here I can give you the 6 foot piece I have in the shed. If you need a longer piece you can run over to BEHRENT'S in Florida, NY and you could certainly get what you need over there. I would have been in for it this week but I'm waiting on the new intercooler to arrive. The old one has corroded clean through in a few spots and there are several leaks from where the core is welded to the end tanks. Hopefully next week I can get it together or maybe Saturday if you guys get together somewhere then.
John
Old Jun 20, 2007 | 01:15 AM
  #713
mudman78's Avatar
Can anyone recommend a good dealership in North Jersey. I need the oil pan gasket and front crank seal replaced (under warranty) and I don't want to take it to some place that sees three trucks a year.
Old Jun 20, 2007 | 10:33 AM
  #714
Bob H's Avatar
Anyone due for Inspection?
Don’t know how the rest of the state is, but I took my truck thru inspection in Newton. Sort of a waste of my time, could have done the whole thing in the parking lot. All they really checked is the lights. Took a quick peek underneath with the mirror, don’t know how they missed it but my tail pipe has lots of holes in it. Didn’t even blow the horn, I guess they know their weak. Never plugged in to the data port to check for codes. I could see all the computer screens they use, so I really watched. Going to the brake check, the screen flashed “FAILED” insufficient brakes for vehicle weight. They didn’t even stop on the brake check pads. The inspector cleared the screen and out I went. Good for two more years. Now all I really have to do is replace the entire exhaust system.
Bob H
Old Jun 20, 2007 | 03:26 PM
  #715
atc250r's Avatar
I've heard that the diesel guy over at Bergen County Dodge on Rt. 17 South in Ramsey knows his stuff. I think his name is Roger and I'm pretty sure he still works there. Unfortunately I don't have any first hand dealings with anyone there but the parts department.
John
Old Jun 20, 2007 | 03:55 PM
  #716
mikmaze's Avatar
heckuva nice afternoon for a car show.... who's goin up to Wyckoff ? show usually runss till almost dark, you know old cars/ lack of headlights thing. few posts back is the link to the Wyckoff DMV wich is right where hte car show is, if ya can't find it from there. well errr....... listen for the train
Old Jun 20, 2007 | 08:58 PM
  #717
Hey you, in the gray Dodge, STOP BLOWING THE HORN- YOU MAY GET US KICKED OUT OF HERE!!!!!!!!!!!!!!!
Thats right folks, the conductor was shot down as he made his grande entrance into the car show this evening. Wasn't there personally to witness it, but, judging from the TDR guy's laughter in telling the story, it was pretty funny. Apparently, Mike made too much noise (which I can't understand because you can barely hear the horn) with his horn and the car club guys are afraid they will not be able to hold their show there anymore. If they are worried about that, they should yell at all the guys doing burnouts as they leave. Should be interesting next week if Mike gets yelled at again.
Cheers
Old Jun 20, 2007 | 10:14 PM
  #718
hmmmm what fun, staying in order with how things have been going for me lately...
got truck back from dealer (ECM reflash to rid me of white smoke on startup), apparently the "tech" felt it necessary to move my seat, mirror and steering wheel, as well as change the display on my radio, and somehow loosened my gauge pod, AND to top it all off: started the truck this morning, white smoke
even better, go to reload Predator, get "your vehicle is not in our database, please contact us...." some more.
but, on an upside, I did get my brothers truck "passed" for inspection this morning, good to go for 2 more years, then it is 10k time
anyway, I will likely be at the carshow Saturday around 5 or so, like I said, then afterwards relaxing with some cold ones, maybe do some tinkering or install some lights. any other takers?
Old Jun 21, 2007 | 11:38 AM
  #719
goodeyesniper75's Avatar
hello again guys, sorry i have been a ghost latly but now that it is nice out work has been a little more time consuming and the baby has to be displayed more now so im sorry for my absence. btw if anyone happens to slip over to the july truck of the month........
Old Jun 21, 2007 | 05:27 PM
  #720
mudman78's Avatar
John
Thanks. I found out the previous owner took it there (never had any Cummins work done though). I'll give em' a shot.
