Indiana Chapter # 29 Get-to-gether
Old Apr 3, 2006 | 04:36 PM
zstroken's Avatar
Muted User
free??
I didn't get any. I thought about organizing a rush and seeing how many we could pry from his cold dead hands though.
Old Apr 3, 2006 | 06:27 PM
Bosshawg600's Avatar
Hey zstroken I saw you had a digital guage on your dash but I dint seee what type it was. What was it? That was a nice truck and put out a ton of smoke!
Old Apr 3, 2006 | 08:03 PM
Andy505's Avatar
Originally Posted by Bosshawg600
Hey zstroken...........That was a nice truck and put out a ton of smoke!
It sure did! hope you don't mind zstroken. Kinda blurry...but it gets the point across. It was sweet lookin'!
Old Apr 3, 2006 | 11:26 PM
zstroken's Avatar
Muted User
Thanks guys. The gage is an airlogic I believe. It is for aircraft, has 6 probes, I am currently monitoring #1 and #6. Eventually I will try to monitor all 6. It doesn't record, but has an auto mode that displays the hottest cylinder. #1 and # 6 seem to be with about 50 degrees of each other.
Old Apr 4, 2006 | 12:17 AM
AAmeeting's Avatar
I had a good time, I brought up the rear with 199hp 421tq ,With Andy505's hypertech. Another guy let me borrow his Edge box and I dropped 3hp and 17tq. My truck is not running the same now. No codes but at idle if you tap the gas it will either rev up or just cough and do nothing. I hope its okay.
Old Apr 6, 2006 | 11:27 AM
PourinDiesel's Avatar
Memorial Weekend Truck Pulls
May 27th 2006
Registration: 12:00-3:00PM Start 4:00PM
Johnson County Fairgrounds
Franklin,Indiana
8000lb Modified 4X4 Diesel Trucks $35
8000lb Street Stock 4X4 Diesel Trucks $30
8000lb Pro Stock 4X4 Diesel Trucks $30
8000lb Johnson County Bragging Rights $20
Diesel or Gas 4X4 Trucks
Street Stock 4X4 Gas Trucks $20
General Admission $5.00
Pit Pass $7.50
Contacts: Scott Logsdon Ray Quinn
317-538-8259 317-441-5359
Volunteers needed please contact above or E-mail us!
scott@srdieselconcepts.com or ray@srdieselconcepts.com
8000 lb. Street Stock 4x4 Diesel Trucks
1. Single turbo,Maximun 2.8 inducer
2. Hanging front weights allowed
3. Must pull off of "Reese" style hitch (I called and verified that this basically means no "trick" hitches that connect to the axle or bed, adjustable hook point type hitches are ok that most of us pull with are ok)
4.Traction bars & blocked suspension permitted
5. 26" Hitch height
6. No Nitrous,Propane, or Water Injection
7. DOT Tires, no cut or bar tires
8. Seat belt or other safety restraint required
8000 lb. Pro Stock 4X4 Diesel Trucks
1. Single turbo, no limit
3. Pulling hitch allowed (26" hitch height)
4. Traction bars & blocked suspension allowed
5. Water injection allowed
6. No nitrous or propane
7. Dot tires, no cut or bar tires
8. Air shutoff or electric fuel shutoff required
9. Manual transmission must have SFI blanket covering bellhousing
10. Seat belt or other safety restraint required
11.Exhaust must exit straight up or down,with two 3/8" bolts in a cross pattern within one inch of each other, and as close to the turbo as practical.
Class Prize Money
Modified 4x4 Diesel Trucks (at least 5 trucks to pay)
1st- $500 2nd $250 3rd $100
Pro Stock 4X4 Diesel Trucks (at least 5 trucks to pay)
1st- $300 2nd $150 3rd $75
Street Stock 4X4 Diesel Trucks (at least 10 trucks to pay) 1st- $150 2nd $100 3rd $50
Street Stock 4X4 Gas Trucks (at least 5 trucks top pay)
1st- $75 2nd $50 3rd $25
Bragging Rights class Trophy only.
Bragging Rights Class Rules:
Truck must be licensed and registered in Johnson County
Driver must live in Johnson County
No Limits on Truck (Must be driven to Pulls)
Guys this looks to be a great pull and should bring out some great trucks!!
This is only 20 minutes south of Indianapolis and probably 5-7 minutes off of I-65!!
PourinDiesel
Competition / Pulls / OffRoad
Jul 21, 2007 12:42 PM
turbox2
Nov 18, 2005 11:09 PM
DieselDaze
Nov 6, 2005 08:29 PM
DieselDaze
Nov 4, 2005 09:43 PM
Lary Ellis (Top)
43
Jan 7, 2003 07:21 AM
