question about the vp-44
just wondering if i should go with a stock vp-44 or should i go with the hot rod vp-44 or is there something else i should go with help me out bc mine is going bad and am trying to make a decision as soon as possable. thanks guys chris
Not true! A HRVP will make more power and it will make more power with a wire tap box. It just doesn't give as much.
I have an Edge and HRVP, dynoed it both ways
My truck dynoed 151 hp stock, 288 with the Edge Comp, and 354 with the Comp and HRVP, and 229 with Comp off.
66 hp more with the HRVP
congrats to you...but hundreds of others out there have all seen the same thing i posted. up until recently with the addition of monster pumps and II's ragon flow pump, the SO pump held the record for highest hp.
HRVP44 is worth it if you dont run a wire tap...but if you are gonna tap the wire, save the $700 and spend it on a set of quality injectors and you will see more gain.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Murf
Aug 17, 2007 04:36 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
