MD Chapter #33 Never Ending Thread IX
Old Feb 23, 2009 | 07:10 AM
  #181
md-rebel's Avatar
Question Am I missing something?
Stupid "lamp out" light is lit but I can't find a bulb out! Exterior, cargo light 3rd brk light ok. Dash lights??? I do have the led bars on the cab rack but they've been ok before.
Old Feb 23, 2009 | 08:21 AM
  #182
Sea:\>Drive's Avatar
Did you replace any lights with LEDs (like blinkers, markers, etc...)? Since LEDs use a lot less power the "lamp out" lights as it doesn't see a large load.
Old Feb 23, 2009 | 08:28 AM
  #183
rollincoal02's Avatar
check tail lights, as well as brake lights, head lights, low beams and high beams, all parking lights
Old Feb 23, 2009 | 09:29 AM
  #184
paroxysym's Avatar
for some reason even when i had a rear brake light out it didnt throw the "lamps out" light. when i had a burnt out headlight bulb, it did. you have stock fogs?
Old Feb 23, 2009 | 05:30 PM
  #185
06 DIESEL's Avatar
It is a common problem on the third gens to throw the lamp out but not have a bulb out. The tail light bulb socket has a tendency to get some corrosion in it causing it to throw the lamp out without actually having a lamp out. Just an FYI.
Old Feb 23, 2009 | 08:56 PM
  #186
md-rebel's Avatar
Sea:\>Drive Did you replace any lights with LEDs (like blinkers, markers, etc...)? Since LEDs use a lot less power the "lamp out" lights as it doesn't see a large load.
Keith, Not replaced but added to cab rack, been ok before for 9 mos.
rollincoal02 Quote:
I've walked around it probably 4 times....
paroxysym for some reason even when i had a rear brake light out it didnt throw the "lamps out" light. when i had a burnt out headlight bulb, it did. you have stock fogs?
Stock, Silverstars in headlights and fogs
06 DIESEL It is a common problem on the third gens to throw the lamp out but not have a bulb out. The tail light bulb socket has a tendency to get some corrosion in it causing it to throw the lamp out without actually having a lamp out. Just an FYI.
Travis, Thanks I'll pull and check the sockets.
Old Feb 23, 2009 | 09:21 PM
  #187
skynyrd's Avatar
you may have walked around it with the running lights on but did you check it with the breaks applied. i had that once the running light was fine it was the brake light that was out. they have separate filaments in the bulb.
Old Feb 24, 2009 | 06:41 AM
  #188
md-rebel's Avatar
Yeah w/4ways on.
Old Feb 24, 2009 | 07:37 AM
  #189
slorocco's Avatar
Originally Posted by DIESELDENT
Hey dan looks like you need to get your sig fixed now that you have the landrover running.
I think the Samurai will fit for now but its probably going to get extended and i just couldnt pass up that much steel for $50
Yeah, I guess you're right. I'll fix that man.
Old Feb 24, 2009 | 10:44 PM
  #190
bootsdodgejn's Avatar
Well thought u guys might like this.
http://www.cumminsforum.com/forum/sh...stack-lol.html
Noticed 2 of ya already posted about it.
Is this guy a member. I'm sure some one has seen it around.
Old Feb 25, 2009 | 06:41 AM
  #191
DIESELDENT's Avatar
Seen the truck around havent seent the stack yet ill have to keep an eye out for it.
Old Feb 25, 2009 | 11:00 AM
  #192
scottsjeeprolet's Avatar
I love Craigslist. Look what i just got today for $230 delivered.
It's a complete 89 YJ motor with the harness. I just needed the harness but a motor came with it.
Old Feb 25, 2009 | 05:27 PM
  #193
ramsport59's Avatar
That is sad....horrible looking.
I've never seen the truck around.
Rick
Old Feb 25, 2009 | 07:07 PM
  #194
fiveology's Avatar
I got that beat, I am picking up a freshly rebuilt 258 with a cam this weekend for the grand total of...FREE.
Now I just need a clean frame. Of course you paid less for your YJ then I did, so I guess now where about even.
Old Feb 25, 2009 | 10:39 PM
  #195
Hey Scott. Has ur ADR ever started flashing saying is defueling. (randomly) while all ur PIDS are in the normal range. I was going down 22 2 days ago and was passing the wawa near hcc. All of a sudden the pulse says its defueling. Come back the other way later same thing. same area. Then today had to go past that same area. SAME THING. Just wondering if that has ever happened to you.
It has never done this before. Its weird.
