Edge system
Old Feb 4, 2009 | 09:39 AM
usmarine110786's Avatar
Edge system
i got my edge juice with attitude in but it still dont work the only thing it does is read the egts and trans temp. it wont change levels, it reads 0 fuel press, and wont fuel past 2200 rpms.
Old Feb 5, 2009 | 06:17 AM
scottsjeeprolet's Avatar
Chris post this over in the 2nd gen performance section.
You can bring it over and we can have a look at it.
Have you called Edge about it?
Old Feb 5, 2009 | 12:35 PM
dzlfarmboy's Avatar
And you have everthing hooked up right? Map sensor, Pump wire tapped,data conection link hooked up and the unit hooked up with a key on power.
Old Feb 5, 2009 | 01:31 PM
yea i hooked everything up and called edge they said i would have to take it to an instlitation specialist. i will bring it over whenever ur free to look at it just let me know thanks.
Old Feb 7, 2009 | 02:58 PM
06 DIESEL's Avatar
He is over here now and everything is hooked up properly as far as I can tell. I did pull four codes though
P-0500 - Vehicle speed sensor malfunction
P-1693 - DTC Detected in companion mode
P-1694 - Fault in Companion Mode
P-1687 - No Cluster bus message
Since I do not have access to a code reader/clearer here for a second gen I am asking that someone out there that has the ability to do with to a second gen please send Chris a PM and try to hook up with him to get these codes cleared.
Old Feb 7, 2009 | 05:46 PM
06 DIESEL's Avatar
I think we might have found the problem. His positive battery terminals were loose so we tightened them. He also had a deal lift pump so we replaced that. The truck seems to be running better now, I will let Chris chime in and let us know how the drive home was.
Old Feb 7, 2009 | 05:50 PM
06MegaCTD's Avatar
**** ya'll had a spare lift pump in the cave lol.
Old Feb 7, 2009 | 07:35 PM
biggerkin's Avatar
Talking you never know
whats in the cave
Old Feb 7, 2009 | 07:44 PM
06 DIESEL's Avatar
Yes there was one in the cave but we were not sure if it worked or not. He bought one at Salvo that has a lifetime warranty, so he is good now.
Old Feb 7, 2009 | 11:15 PM
md-rebel's Avatar
Originally Posted by biggerkin
whats in the cave
No one really knows ......... (add creepy laugh)
Old Feb 8, 2009 | 12:03 PM
well i still have codes thrown and i need to get the ecp reset on the truck if anyone knows where i can get the computer reset.
Old Feb 8, 2009 | 02:40 PM
We have a code reader at work. I'll bring it home and we can clear the codes with it.
Old Feb 8, 2009 | 07:17 PM
lukedaemon's Avatar
I have a scanner/reader too. Not the top of the line type, but does the job.
Old Feb 8, 2009 | 09:10 PM
rollincoal02's Avatar
find someone with a smarty local...it will clear the codes
Old Feb 9, 2009 | 08:29 AM
bootsdodgejn's Avatar
I know i always have. Vehicle speed sensor malfunction code. Going to check into at school today in advanced diag class.
