Making my Old Smokey Mount/BHAF (pics)
Old May 19, 2007 | 10:31 PM
BRUISER's Avatar
Well I bought the larger air filter (BHAF) a while back and just have been waiting for some free time to install it.
Well today a buddy and myself decided why not lets make it.
So we first took out the old air box and hose..
first pic shows old factiry air filter
this pic shows the stock air intake hose
Here is the box and the air tunnel out of the truck.
Then we took some comparison photos to show the factory vs. BHAF
wow that is a big filter
Old May 19, 2007 | 10:35 PM
BRUISER's Avatar
Then we got started on the making of the Old Smokey Mount
we took some sheet metal we had laying around.. and used the following diagram:
https://www.dieseltruckresource.com/...sort=1&cat=522
we did modify it a little.. instead of 1/2" break we made it 1.5" so it fits up under fender and help hold the mount in place with more metal..
we also moved the angle 45 degree cut up a little so that way I could leave the overflow coolant container in its stock position
Here is the mount in the middle of cutting the steel
this shows it all cut and bent up
then we made a steel strap to go around the filter to keep it in place
Old May 19, 2007 | 10:38 PM
BRUISER's Avatar
After it was all cut and bent I took some Silver paint I have and painted it all to keep it from rusting
Here is the finished mount done and in the truck
One more pic from different angle
Of course while I was under the hood I could not help myself so I turned up the HP screw ONE full turn and WOW what a difference these two things together did for my power, and of course it is really cool to here the turbo wind up
all in all it took the 2 of us 3 hrs to make the mount, paint, get it in truck and turn the power up.. Not a bad saturday
Old May 20, 2007 | 11:42 AM
Diesel_Dawg's Avatar
That looks great! Would you be willing to make one for me and if so how much? If you are not willing to make another one, can you tell me how much you moved the 45 deg angle to clear the coolant recovery bottle?
Thanks,
Chris
Old May 20, 2007 | 12:32 PM
BC847's Avatar
1st Generation Admin
Nice work Ken.
Old May 20, 2007 | 01:00 PM
GasganoFJ60's Avatar
That looks really nice. Im working on making mine right now based on the same diagram. Itll be a little unique though. The metal Im using for the mount is something a little special. Ill hopefuly have it finished by the end of today.
By the way, where can I find the BHAF cross reference numbers?
Old May 20, 2007 | 02:13 PM
DanMan's Avatar
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere pmah19037
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
Outerwear cover wr3325-105
Old May 20, 2007 | 02:14 PM
DanMan's Avatar
What is the part # for the Amsoil Nanofiber filter that fits?
Old May 20, 2007 | 02:19 PM
b.lee's Avatar
can you get some more pics of it thru the wheel well?
is it closed?
how will it work in heavy rain or muddy / backroad situations?
Old May 20, 2007 | 04:51 PM
BRUISER's Avatar
Thanks,
Chris
I cut 3/4" up on the 45 degree area..
I had to force the mount past the coolant container, but it was really not much force at all.
Old May 20, 2007 | 04:54 PM
BRUISER's Avatar
The outer cover/sleeve is the only thing I have left to get
Old May 20, 2007 | 04:55 PM
BRUISER's Avatar
is it closed?
Wheel well is sealed..
I have not heard of anyone having issues with rain..
as for Muddy roads I do my best to stay away from them.. and if I go down them I go slow.. that is what my Jeep is for
Old May 20, 2007 | 05:42 PM
dieselJon's Avatar
Great pics!
Jon
Old May 20, 2007 | 07:30 PM
Thanks for the dimensions.
Old May 21, 2007 | 07:56 AM
BRUISER's Avatar
No problem..
the other thing I forgot to list is I bought some of that black plastic door trim that I put on edge of the metal, to make sure I do not get cut by the edges..
