ISBe flywheel housing
Old Jan 28, 2010 | 10:52 PM
1-5-3-6-2-4's Avatar
Exclamation ISBe flywheel housing
are the HPCR flywheel housings, the same on the HPCR as the VP44 ISB 24v?
reason I'm asking is 1st thing tommorrow AM, I have to go do a rear main and change the flywheel housing on a HPCR 2005 engine. but I've only got upto a ISB 24v manual for specs.
the FWH is broken. if anyone is wondering why.
Old Jan 29, 2010 | 12:07 AM
bump for the night shift.
looking for specs to dial the housing.
Old Jan 29, 2010 | 07:40 AM
kthiemann's Avatar
The adapter plate is different, starting with the Common rail engines there is a groove in the back of the housing that holds on o-ring that seals the camshaft at the rear of the engine, I've seen a couple of those o-rings develop leaks that look just like a rear main leak so before you change the that you might take a hard look at that o-ring. If memory serves it mounts just like the old adapter plates you just have to be sure that the o-ring doesn't slip out of place or you'll have a massive oil leak.
Old Jan 29, 2010 | 06:21 PM
So I did the job this morning. and the engine is a rear gear train ISBe 5.9.....what the hack. I never knew there was a rear train B engines out there. shocked the heck out of me when I was inspecting it. Its nothing like you describe being a rear gear train engine.
Old Jan 29, 2010 | 08:59 PM
this thread is resolved now..........but
the situation.......
the rear geartrain.....
Old Feb 1, 2010 | 07:28 AM
patdaly's Avatar
Only rear gear train B model Cummins I am aware of ( And I don't know if Cummins calls it a B ) is the little 3.3 4 Cyl, made by Komatsu for Cummins. Perhaps there is a smaller 6 Cyl. version?
Pictures would be helpful.
Old Feb 1, 2010 | 06:21 PM
can you see the pics i posted already?
heres some more.
Known facts....... 6 cylinder cummins, 2005 model year, commonrail injection, EGR engine.
CP3 and aircompressor are the 2 gears in the rear housing.
Old Feb 1, 2010 | 07:44 PM
kthiemann's Avatar
Just out of curiosity what is this thing in? I've never seen anything like this, it almost looks like it is installed backwards.
Old Feb 1, 2010 | 08:06 PM
Its in a 2005 Ottawa Shunt truck........
Not this one, but just like it......
Old Feb 1, 2010 | 08:45 PM
pind's Avatar
QsbE engine
Rear geartrain equipment engine.
I have worked on bigger Q series stuff before, and all of them had their little quirks.
Old Feb 1, 2010 | 09:24 PM
but it says ISB right on it. in the model line on the tag, you can see it in the pic.
*edit* well its kinda blurry there. but it says ISB 215 in the model spot.
Jona Gold
29
Jan 19, 2025 06:36 PM
4doogie
Dec 7, 2006 08:05 PM
Superduty
Jun 10, 2005 08:47 AM
