Won't start
Old Mar 18, 2006 | 10:07 AM
mkrenn's Avatar
Won't start
OK, installed new injector nozzles and now we have to bleed it to start it everytime it sits for more then 30 mins. When the new nozzles went in, we made sure that the push tubes (brand new) got seated properly. These nozzles were professionally installed on the injector and new o rings and copper seats were added. Any ideas? Moms getting tired of giving up her Jeep! Thanks,
Mark & Brandon
Old Mar 18, 2006 | 09:19 PM
RCW's Avatar
RCW
Assuming the problem started with the injector change, I would check to be certain that you used new O-rings, and that you properly torqued the injector hold down bolts. Too much torque will distort the O-rings and allow leakage that lets air into the system and will lead to drain-back of your fuel. Also, be sure you did not undertorque the high pressure fuel line fittings. Air leaks are real common with low torque, and you will get internal fuel leaks and air leaks with too much torque.
Old Mar 18, 2006 | 11:02 PM
Sixpack's Avatar
Silly question but, did you make sure ALL the old copper seats came out with the old injectors?
Phil
Old Mar 19, 2006 | 10:18 AM
mkrenn's Avatar
All O rings were new. Copper seats are new. Injector retainers were torqued to 90 inch pounds (spec). How does a guy torque the fuel line fittings? We just tightened as much as possible with an open end wrench.
Old Mar 19, 2006 | 10:30 AM
Sixpack's Avatar
A crows foot and torque wrench. I never have used one, but to be right on spec one should.
Old Mar 19, 2006 | 11:08 AM
mkrenn's Avatar
Thanks six. I'll try it. Any other ideas? anyone?
Old Mar 19, 2006 | 12:30 PM
torquefan's Avatar
Lubing the o-rings with a small amount of engine oil before assembly makes a big difference.
Old Mar 19, 2006 | 03:29 PM
mkrenn's Avatar
Did that TF.
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
