wont start
Old Mar 13, 2008 | 07:51 PM
kidhulr's Avatar
Angry wont start
well here i go again. got my truck stuck at the end of the driveway. got down to 10 deg. and didn't plug it in. started it up the next morning ran for a few minutes then died. got it out and to the garage plugged it in and waited until it warmed up. still won't start. changed fuel filter nothing, opened drain with fass pump running and had much fuel. cracked pressure valve cranked it and nothing, removed valve all the way and still no fuel spray. saw a post about a gun i'm about ready for TNT.
Old Mar 14, 2008 | 01:02 AM
tristan21's Avatar
Pull the supply directly from your fass to where it would pump out in a bucket and see if its getting that far. I suppose your not running the full fass system?
Maybe its a problem in the lines themselves. where do you live? I would guess most places are running winterized fuel. Im sure you checked fuses? Can you hear the fass running?
Old Mar 14, 2008 | 04:14 PM
kidhulr's Avatar
i opened the water drain valve and have plenty of fuel from the fass into the stock filter. the problem is somewhere past the stock filter. is there a way to check the fca? other than removing and shaking?
Old Mar 18, 2008 | 08:46 PM
kidhulr's Avatar
any other ideas? something else to try?
Old Mar 18, 2008 | 09:00 PM
RCW's Avatar
RCW
The way the CP series injection pumps are designed they can get ice crystals between the front and the rear castings and refuse to pump or in the regulator port and shut them down. Take a hair dryer and warm the injection pump so it is warm to the touch, then prime it and it should start if it was not missing before the problem started with the cold.
It is a really good idea to use both an anti-gel conditioner and a water disbursing diesel fuel system anti-freeze in weather below freezing.
Old Mar 18, 2008 | 09:04 PM
kidhulr's Avatar
i waited until temp reached high 50's here and still no luck would the hair dryer still help?
Old Mar 18, 2008 | 09:10 PM
RCW's Avatar
RCW
Probably not if the engine block and pump are above freezing. Pull the codes and see what you get.
Old Mar 18, 2008 | 09:14 PM
kidhulr's Avatar
0628 because i bypassed the ecm with a toggle switch for the fass and 2509?
rustydeeretech
Jun 16, 2010 09:41 AM
CoolumConst
Oct 11, 2008 10:00 PM
Stroked-Z
Oct 4, 2008 11:28 AM
qcstunter
Jan 9, 2007 04:10 PM
Desert Diesel
Dec 5, 2002 08:53 PM
