What would cause this code?
Old Oct 24, 2006 | 07:27 PM
BigDave12768's Avatar
Have you checked the Flux capacitor?
Old Oct 24, 2006 | 09:20 PM
53 willys's Avatar
this is a total guess but maybe it's the speed sensor that is located right by the transfer case?????
they are fairly cheap ($20-35 bucks?)and can be found at Autozone or Checker Auto.
you could slap on in yourself in 5-10mins.
Old Oct 24, 2006 | 09:32 PM
53 willys's Avatar
I also found this.....
WHEN MONITORED
Key on or Engine running.
SET CONDITION
Speed Control MUX switch above 11.5 volts for 5 seconds .
POSSIBLE CAUSES
S/C Wiring harness observable problem
Clockspring signal/ground circuit open
Speed control on/off switch
S/C Switch signal CKT shorted to voltage
S/C Switch signal circuit open ECM to clock spring
S/C Switch signal circuit open clockspring to S/C switch
S/C Switch ground circuit open clockspring to S/C switch
S/C Switch ground circuit open ECM to clockspring
ECM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding.
Old Oct 24, 2006 | 09:52 PM
53 willys's Avatar
Originally Posted by Pull U 2
Your second reply is probably dead on! They replaced the steering wheel also because it was pealing and I see on the work order that they replaced the clockspring(whatever that is)
the clockspring is the part inside/on the back of the steering wheel and it is there to make the electrical connection for all of the electronic stuff on the wheel like the cruise control, horn, airbags......
53
wilderness
Oct 17, 2006 02:38 PM
BigBully
Jul 2, 2006 09:02 PM
Tree DR
17
Apr 29, 2006 10:21 AM
ratsun
Dec 1, 2005 08:29 PM
bigbaddiesel
Nov 30, 2002 08:17 PM
