what is the whining
Old Jan 25, 2010 | 08:20 PM
derceg's Avatar
what is the whining
i was coming home from towing a car from a 200 mile trip. shortly before coming into town, i started hearing i loud whining/whistling. it was dark, so i couldnt look around to check what was going on. did i blow a boot, crack a manifold, blow a turbo, what do i need to check. any ideas what it could be. im not getting the boost like i should be. i have never really gotten the boost i think i should (only around 40.)
Old Jan 25, 2010 | 09:05 PM
kthiemann's Avatar
Sounds like you might have blown a boot off, or have a loose boot clamp..at least that's the first things I would check out.
Old Jan 25, 2010 | 09:09 PM
derceg's Avatar
im hoping thats it. i have bd boots and spring clamps on it. i find it hard to believe thats going to be it though, because i never really boosted past 30-35 today.
Old Jan 26, 2010 | 02:40 PM
BigIron70's Avatar
Cummins Guru
Check the exhaust manifold bolts, make sure they havn't loosened up on you causing exhaust leak. The rear bolts have a habit of coming loose, also look for any soot on head near exhaust, tell tale sign your bolts are loose or gastket has blown out.
Old Jan 26, 2010 | 03:18 PM
derceg's Avatar
did a little bit of checking. the whine is coming from around the turbos. lots of soot. looks like v clamp off top turbo is giving way. don't know if thats the only cause. too cold outside to stay out long.
keithplacervill
Oct 26, 2005 11:22 PM
Life is Life
Aug 3, 2005 06:17 PM
Firefighter22
Apr 11, 2005 06:03 PM
Ramrider
Aug 29, 2003 07:27 PM
RAY CHAMBERS
Nov 10, 2002 05:18 PM
