What size is the bolt on the hub assembly?
Old Aug 31, 2006 | 05:48 PM
meanfarmer's Avatar
I'm going to replace the rotors on my 98 dually on the back of the hub assembly there is a strange bolt what size is that? and where can I buy a socket for it? I'm guessing it's metric. Any tips or advice on replacing the rotors would also be appreciated.
Old Aug 31, 2006 | 07:03 PM
meanfarmer's Avatar
I crawled under there it's a twelve point. But I still need some good advice on the rotors and hub removal. Thanks for any advice on this.
Old Aug 31, 2006 | 07:51 PM
JKM's Avatar
JKM
The bolt is a 9/16 head 12 point.
Old Aug 31, 2006 | 11:33 PM
DeweyND's Avatar
Farmer,
12 point 14mm works too, atleast, on my 01 it did....
Dewey
Old Sep 1, 2006 | 02:19 PM
slayerfish's Avatar
Its actuaally a 14mm 12 pt. Do a search on the rotor procedure.
Old Sep 2, 2006 | 06:19 AM
berner's Avatar
9/16" is slightly bigger than 14mm. You stand the chance of rounding off the bolts using a 9/16" if they're rusted in there.
c-bass
Mar 21, 2013 04:25 PM
Mark Hodowanec
Jun 17, 2009 12:04 PM
Rafter B
Jan 11, 2009 08:40 PM
cmnspwr
May 15, 2006 08:20 PM
