Hub Bolt Size - Changing U-Joints
Old Jun 16, 2009 | 04:43 PM
Mark Hodowanec's Avatar
I'm going to change the axle u-jopints. Will remove the four bolts holding hub to housing, replace w/ some sacrificicial bolts and "convince" the hub to separate from the housing by beating on the bolts. What is the bolt size so I can buy some sacrificial bolts in advance?
Old Jun 17, 2009 | 11:36 AM
jballou's Avatar
Don't beat on the bolts with a hammer. Not enough room and won't work well.
Loosen them and then use a sacrificial socket on the end of the bolt with an extension to push off from the axle housing with the power steering. Works like a large gear puller, as a pusher.
Easy peasy chicken squeezey.
Need more how to?
Old Jun 17, 2009 | 12:04 PM
Need more how to?
Was intending on trying it this way, but if I could not get it to work, then hammer on the bolts while applying PS pressure.
c-bass
Mar 21, 2013 04:25 PM
Rafter B
Jan 11, 2009 08:40 PM
meanfarmer
Sep 2, 2006 06:19 AM
njmaier
15
Jul 26, 2006 07:43 AM
