what am i looking at?
drivers side towards the front of truck after the radiator is a small canister with a rubber formed hose. the hose starts from the motor then travels up and then upside down towards this canister. the hose enters canister from top portion. at this time, the canister is covered with some sort of liquid with dirt stuck onto it.
the whole underside of truck is wet and caked with road dirt and sorts.
what is this and does it require maintainence?
HELP
HELP
That's the engine blow-by cannister. It gets full or plugged and causes a mess. Most people re-route the hose to below the front axle or reposition the bottle. Whichever you do, be sure the hose or bottle has down hill travel from the engine. You can do a search and find lots of info.
Also, you will need to clean the fan blades and the back of the radiator if it's that bad.
okay...
i recall other members with an extension of this tube up and around the top and then back towards the ground.
is it necessary to retain that bottle at end? or just extend it with no cap or?
thanks
thanks
Just leave the end open and let 'er rip.
Be VERY sure there are no down-hill, up-hill, down-hill runs in the extended hose run.
It will act like a plumber's P-Trap and allow moisture to be trapped which will freeze preventing the expanded gasses from leaving the crankcase resulting in blown engine seals.
F1B3R
Jan 2, 2011 08:59 PM
89dieselkong
Feb 12, 2010 12:47 AM
theIntlEggrole
Jul 16, 2007 05:53 PM
bob95065
39
May 7, 2007 09:48 PM
