Water/fuel filter service?
Old Feb 20, 2004 | 10:09 AM
mthomas's Avatar
Question Water/fuel filter service?
Hi there,
An easy question - just something I've never done before...
Got a '96 and need to change the water/fuel filter. I've drained the water @ each oil change but it's been a year since the filter was changed.
Can someone walk me through the steps?
Thanks, Mike
PS. I like the new look on this page - good job...
Old Feb 20, 2004 | 11:20 AM
infidel's Avatar
For good instructions click here
What they don't say- to make it much easier to change the filter on your '96 remove the two nuts that hold the master cylinder to the brake booster and pull the whole unit towards the driver's side. It doesn't look like it moves easily but it does giving you tons of room to get at the filter.
I don't agree with prefilling the filter unless you have some filtered fuel around. You're just asking for trouble.
The way I fill and bleed fuel filters is a snap if you have compressed air. Just open the filter bleed screw and use an air blow gun wrapped in rag to pressurize the fuel tank though the fill hole. Takes about 15 seconds to fill and bleed the filter. Sure beats pumping the manual primer.
Old Feb 20, 2004 | 04:06 PM
kd460's Avatar
Infidel, great idea on the filter priming! I'm gonna remember that one. Thanks, Kevin
bakerroc
Feb 16, 2015 11:11 PM
dieselfuelonly
Jan 24, 2012 10:16 AM
ZPOD
18
Sep 23, 2010 10:37 AM
dart3404
Oct 12, 2009 03:35 PM
motrapper
May 3, 2006 05:37 PM
