VP44 Injection Pump. Where is it??
Old Aug 23, 2006 | 02:58 PM
1999DodgeRamCum's Avatar
1999 Dodge Ram 2500 4x4 Cummings Diesel turns over but doesnt start. So I will try this pump. Where is it located?
Old Aug 23, 2006 | 03:57 PM
blackdiesel's Avatar
Registered
WELL you need to do some checking before you start throwing around that kind of money (1k) but it's right on top, on the driver's side (it's the one with all the fuel lines coming out of it). GOOD LUCK. I would check the codes and the fuel pressure first, but that's just me
Old Aug 23, 2006 | 04:47 PM
Rauschbo's Avatar
BlackD is correct, you should troubleshoot before putting a $1 - $1.4K VP on the truck, you could end up frying that one right away as well, if the IP is shot....
Do you have a FP gauge on the truck? If not, a first-cut look would be to check the fuel filter, make sure it's not plugged / clogged, then get a schrader valve put on the VP side of the fuel filter, and hook up a gauge there to see if you have good - or any! - pressure going to the VP; If all seems well there, the next place to look for fuel is at the injectors, crack a few of them to make sure you've fuel there.
Fill in your signature with everything relevant about your truck, site members can then better assist in troubleshooting / making recommendations -
Rauschbo
Edit / Note: Troubleshooting the fuel systems on these things really should include the pickup tube in the tank and all fuel lines to the LP and VP, a plugged tube or pinhole(s) in the lines can shut these trucks down
Old Aug 23, 2006 | 05:48 PM
runamuk's Avatar
If you are going to do it yourself replace the lift pump also.
Get your codes read with a code reader and let us know.
This may help if you actually have a bad VP44.
https://www.dieseltruckresource.com/...4+installation
Good luck to you!!
Rick
tommurray
Feb 23, 2014 10:38 AM
RAM123
Jan 11, 2010 07:56 PM
Mountain Grown
Jul 30, 2009 01:50 PM
adgr71
Nov 28, 2005 07:34 PM
rmrc
Feb 24, 2005 08:04 PM
